SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 11-05-2008, 05:37 PM
EarlsflyinCobra's Avatar
Ouch Ouch Hot Sand
Cobra Make, Engine: Street Beasts w/302 Twin Turbocharged....Under Construction!!
Send a message via AIM to EarlsflyinCobra
Default T5 with S10 tail piece
Has anyone done this conversion for a Cobra?
Does it change the length of the drive shaft?
Any help would be appreciated......thanks
Safe Flyin, errrrr Drivin, Earl
Old 11-05-2008, 06:09 PM
Club Cobra Member
Cobra Make, Engine: SPF
Send a message via AIM to Tinker51
Are you trying to replicate the shifter position of a toploader by putting the S10 tailhousing on a T-5?
We have enough youth. What we need is a fountain of common sense
Old 11-05-2008, 11:15 PM
Maurice Butler's Avatar
Cobra Make, Engine: Scratch build, with help
Speedo cable end different, speed gear different position, not world class box
not sure if yoke different,
input shaft 6" (ford) vs 6.6" (chev) on t5550 may or may not apply
see also http://www.5speeds.com/t5
Maurice
researching for scratch build
Old 11-10-2008, 03:34 PM
Jimi G's Avatar
Give Standard Transmission & Gear a call but only talk to Charlie Jetton he is the GM and knows all about them, I learned eveything I know about high performance Tremec and custom transmissions from him. I wouldn't recommend talking to any of the other salesman or you might regret calling. I worked there and we did this to some Ford units but I can't remember what exactly we had to do to make the S10 tail fit on the Ford main assembly.
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
Old 11-10-2008, 04:59 PM
Cobra Make, Engine: HI-TECH 289 FIA
I have done it. World class or not has no bearing on the tail shaft. Out put length is the same. Speedo end must be replaced and speedo drive gear need to be adjusted.The s10 has a different shift rod and offset lever. These are just part swaps. The speedo drive gear is the only problem. The gear fits too loosely on the output shaft so it must be shimmed in its new postion. Yoke is the same, Ford. Shifter is different for other T5s. S10 came with either an electric or cable speedo drive. Make sure to get the cable model. Housing is a straight bolt up. Changing overdrive ratios is a whole nother subject. I used a new T5z box with the s10 housing
fiaroadster
Old 11-10-2008, 08:34 PM
Forgot to mention that the speedo driven gear assembly must be changed in addition to the cable end.
fiaroadster
