SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 02-12-2009, 07:21 AM
Woodz428's Avatar
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
Default Mod motor and SBF pattern the same???
O.K. you knowledgable Mod gurus, I am not.I have a running discussion with another individual regarding the bellhousing pattern on the Mod engine vs. the SBF. I am under the impression from several articles and the FRPP catalog that the Mod motor has a unique pattern to the SBF and he informs me that they are the same. He's not a Ford person, but claims to be a tranny swap guy( whatever that is). Some input please??
WDZ
Old 02-12-2009, 07:50 AM
Woodz428's Avatar
I called Sean Hyland and he informed me that they are completely different, which is what I suspected. If there is any other input though, as to adaptability, I'd like to hear.Thanks.
WDZ
Old 02-12-2009, 11:25 AM
Cashburn's Avatar
Backdraft Racing Dealer
If it is simply a bellhousing issue then Quick Time makes the housings to mount anything to anything it seems...
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 02-12-2009, 02:16 PM
Woodz428's Avatar
It's an issue of whether a SBF pattern will bolt directly to the Mod engine. A guy is installing a Mod motor in an early 'stang and was interested in what trannies would bolt to it that were stock, it was suggested to him that he could bolt any SBF bellhousing pattern up to it. He's doing it for someone else and is trying to avoid adapters if possible, I already told him about adapters for the manual as well as a C4.
WDZ
Old 02-12-2009, 05:52 PM
I do believe that the 1992 Mod had the same bolt pattern as the 5.0 (95% sure). Then they went to the other pattern. Knowing Ford there well could have been some carry over into some later cars. Also there are two Mod engine plants and they are not identical.
Anyway the first year Mod with the same bolt pattern as a 5.0 also had a different starter. One bolt more or less - not sure.
There should be lots of 1992 crown vics in the junk yards, if you wanted a block that would bolt up. I hope that helps.
Old 02-12-2009, 06:44 PM
Cashburn's Avatar
We just put a 4.6 DOHC in a '67 Mustang and bolted op a T-56 to it with a Quick Time bell. The shifter is perfectly centered in the factory opening.
VINTAGE MOTORSPORTS
Old 02-12-2009, 07:58 PM
Hi WDZ,
The SB Ford bellhousing bolt pattern includes 1965 & up 289, 302, 351-W & 351-C. The 4.6 ltr. mod engine from Lincolns, Mustangs & 5.4 ltr. in the 2000 Cobra R, GT-40 & truck are totally different from the SB Ford. The 157 tooth flywheel SB Ford has a 2 bolt starter & mod engine has a 3-bolt starter. The 4.6 T-45 & TR 3450 have an integral bellhousing so swaps are out with mod trannies.
I hope this info helps. Call me with any questions.
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
