SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 04-06-2009, 06:30 PM
Cobra Make, Engine: modified 289 small block
Default gorrilla clutch pedal
Installed a 7/10 master cylinder to a 7/8 external slave cylinder on a toploader trans with a 10inch Ram finger clutch. I need to be a gorrilla to depress the pedal. I'm using a 65 mustang pedal assembly, with the original pivot points. The leverage is not there.
Old 04-06-2009, 07:02 PM
vettestr's Avatar
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
increase the hydraulic ratio
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 04-06-2009, 07:06 PM
increase means smaller master. Correct?
Old 04-06-2009, 07:09 PM
Hi sbh,
What was wrong with the .7" master you replaced? The .875" would increase the effort (pedal pressure) and travel.
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
Old 04-06-2009, 07:15 PM
Slill have the 7/10 master, with the 7/8 slave. Started with the 7/8 master. forget about moving the pedal without cramping
Old 04-06-2009, 07:24 PM
Still have the 7/10 master, with the 7/8 slave. Started with the 7/8 i believe master and no good. This is the only thing left til paint.
