Old 06-18-2009, 10:00 AM
STEVE POTTS's Avatar
Cobra Make, Engine: Midstates, 427FE stroked to 482CI
Default early toploader 5 bolt bellhousing
Can someone measure a T10 or early toploader bearing retainer(for 5 bolt bellhousing) and give me the outside diameter of the retainer(where it mounts to the bellhousing)? I need this dimension to reduce the diam. of my toploader bearing retainer(for 6 bolt bellhousing) which measures 4.85". Thanks
Old 06-18-2009, 02:24 PM
Clois Harlan's Avatar
Hey Steve,
I think that diminsion is available at David Keys http://www.4speedtoploaders.com/ web site or another similar site,www.toploaderheaven.com:
Clois
"Let's roll"
"Be part of Something Good
Old 06-18-2009, 05:41 PM
No, those sites do not have this information.
Old 10-21-2014, 05:03 PM
V8er's Avatar
Cobra Make, Engine: 289 FAIRLANE SPORT COUPE ENGINE
Anyone know the part# or casting# on the 5-bolt steel "COBRA" bellhousing, have pics of one, OR know of one available? You can email or PM, if you'd rather. THANKS!
Old 10-21-2014, 05:28 PM
Rick Parker's Avatar
"Bellhousing Cobra" on Ebay, 1ST one up is cast iron for 289/302 6 bolt
10/21/2014 4:29 pm
Old 10-21-2014, 05:43 PM
legenmetals's Avatar
Default bellhousing
I polished this one and painted it with gloss black.
Old 10-21-2014, 05:51 PM
*13*'s Avatar
Why is it that you want a part number? They, obviously, are no longer made.
ERA FIA 2088
Old 10-21-2014, 07:24 PM
Jac Mac's Avatar
Steve,I would suggest that the bell housing for compact Fairlane etc with 3 speed manual from 62 thru 64 that uses the inner bolt pattern that all later top loaders etc have but don't normally use would have the diameter on that front bearing retainer/clutch release sleeve that you require the dimension from, soo if you can find a 3 speed trans from one of those to measure it might help...check it against your bell housing dia to be sure...why can you not simply measure your bell housing and work off that?
Jac Mac
