Go Back   Club Cobra > Club Forums > Tri State Cobra Association
Old 07-21-2011, 09:31 AM
Jimeg's Avatar
Cobra Make, Engine: ERA FIA Street #2122 , 302ci
Default Vulcanize a tire ?
Well I just got my first tire puncture on my rear Goodyear Eagle F1. It was at night so I had to be flat bedded home. Fortunately only 5 miles away. Thank you AAA!
I must have run over something big as after I plugged the hole, I still have a slow leak and have to fill a few Lbs every couple of days.
Not to be a cheap skate, but at over $400 for the tire and only 1500 miles on it, my thought is to have it vulcanized.
Any suggestions with vulcanizing? Anyone know a place in South Jersey that does this?
Thanks.......
We Few, We Happy Few, We Band of Brothers..............
Old 07-21-2011, 11:53 AM
Bob In Ct's Avatar
If by "vulcanized" do you mean to have it removed from the wheel and a rubber patch applied to the inside? If so, that's what I would do. Get it rebalanced after the procedure.
I'll bet it was a rear tire.
Old 07-21-2011, 12:04 PM
Cobra Make, Engine: 427
if the mechanic has very pointy ears you're assured of a good Vulcananization
Old 07-21-2011, 12:21 PM
Jimeg's Avatar
Thanks Bob and yes it was a rear tire. The Eagle F-1's have a very wide pattern and of course I picked up something between the treads
Old 07-21-2011, 12:23 PM
xlr8or's Avatar
Neutral
Yep... patch from the inside. Kind of a pain but much cheaper than replacing a $400 tire.
Old 07-21-2011, 12:25 PM
Jimeg's Avatar
Mr Spock, I need you to come over with those strong arms of yours. I believe you are probably a pro at pounding those spinners off. .... V .....
Old 07-21-2011, 01:32 PM
CobraEd's Avatar
Only Alvin Vulcanizer from the movie "Nothing But Trouble" can do it.
________
________
Old 07-21-2011, 01:41 PM
twobjshelbys's Avatar
You're just patching. "Vulcanization" is the chemical process of "curing" rubber.
If you patch you should never ever race the car. For street use you'll be OK - I have a patch in one of the tires on my truck - but there is now a weakness at that spot.
CSX4005LA
Old 07-21-2011, 02:06 PM
Is a tube a good option?
Chas.
Old 07-21-2011, 02:22 PM
Jimeg's Avatar
No, not racing the car. So I'll be taking the wheel and tire off and trying the patch route.
Thanks for the comments....
Old 07-21-2011, 03:06 PM
Bill Bess's Avatar
It's worth a shot to fix it.
We use to put what we called a "boot" or large vulcanized patch on the inside of the tire when a plug wouldn't hold.
Recently most Major Tire Shops won't do this, especially if the steel wire is damaged by the nail or whatever punctured the tire, I think it's a liability matter, they can't even sell used tires in Ca. and AZ anymore.
if the wire mess is not damaged a good old patch and perhaps a tube will work, but don't go too fast...you never know.
Good luck, find a good old time gas station or small tire shop...they will most likely fix it.
Bill
Old 07-21-2011, 03:18 PM
Jimeg's Avatar
Bill
Well Bill you might be right, I called out to five different shops and all said no can do. I did find, as you also suggested, a small shop that would do it but there was no guarantee it would hold up. At this juncture it appears I'm going to spend the $400 or so for a new tire.
Old 07-21-2011, 05:21 PM
yes Captain let me know.
Old 07-21-2011, 05:47 PM
Jimeg's Avatar
I might be the Capitan but your steering the ship....
let me know when you can make it. Hey...and don't be concerned, I have a Hammer.
Old 07-21-2011, 05:48 PM
joyridin''s Avatar
What did you use to plug the hole? We used to use rubber plugs and vulcanizing rubber cement from NAPA. It would literally melt the rubber plug into the tire. Then after we let it cure, we used a die grinder with a scotch brite pad and buffed up the inside of the tire. A patch was then applied.
As long as the cord (steel or whatever) wasn't cut, it was safe to do whatever. If the cord had strands broken, it was for street use only.
Old 07-21-2011, 06:12 PM
I
if I had a hammer I'd hammer in the morning, especially being that it's going to be like 110° tomorrow
I sent you an e-mail a couple hours ago for my cell phone .
Old 07-21-2011, 06:24 PM
crASH's Avatar
I patched tires in the 70's as a teenager at the Sears Auto Center and tubed them when necessary as well. Tubes can blow out as I recall.
