Turn Ten Racing, Inc. and D&D Cobra of Quebec
Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Turn Ten Racing and D&D Cobra
User Name
Password
Club Cobra Home Register FAQ Members List Calendar Today's Posts
Old 08-10-2010, 05:19 PM
Cobra Make & Engine: D&D Cobra,302 stock for now,IRS
Send a message via Yahoo to michel schryer
Default Shifters style feedbacks required !
For the guys that have a DD Cobra EVO5 what shifter are you using if you have a t-5.
I am using a shifter handle that I bought from a FFR forum member,it's the standard straight chrome shifter with the black ball that FFR supplies with the kit,I think finishline sell it too.
I would like to know what would be a better choice,I know this one looks period correct but it's a little long and read that it could bent the forks eventually because of the leverage and the force that it exert on the forks. If I'm right. Anybody experimented with short throws,what's your experience and what brand did you use or are using. I know there's only a handful exclusive DD owners but let me know what you've got,thanks guys !
Michel ( cobra registered,inspection soon when I can)
Old 08-15-2010, 05:05 AM
Default Shifter
Michel I also have the FF5 shifter handle and I cut it at the weld and shortened it and changed the angle to suit the D&D. The only difference is that I have a TKO trans but as long as you don't beat the crap out of the trans you will be fine.
Cheers Greg
Old 08-15-2010, 06:55 AM
Dwight's Avatar
I contributed to CC in 2006
I have in the past contributed to CC
Cobra Make & Engine: RCR GT 40 & 1966 Fairlane 390 5 speed
Smile
Coach had a long chrome FFR shifter in his black FFR. He had me to heat and bend it so he could shift better. He liked it and used it for several years before he sold the Cobra.
I'll try to post a pic of it.
Dwight
Old 08-15-2010, 07:00 AM
Dwight's Avatar
Smile
I found a pic
Coach Mike did not have to get it rechromed because the shifter boot covered the bend.
Dwight
Old 08-15-2010, 07:54 AM
SF_SN888KE's Avatar
Cobra Make & Engine: Cutting Edge Replicas, 427 World block SBF, TWM Injection
I just got a Jordon Shifter - track shifter, for my mid shift TKO600, angled towards the driver about 10-15* (not straight stick). Each shifter is custom built and not in stock. expect to wait 4 weeks. Heavy duty and chrome.
http://www.secondstrike.com/SecondSt...danShifter.htm
Ron; SF_SN888KE
Cutting Edge Replicas 427
Shell Valley Daytona #27
Old 08-16-2010, 05:48 PM
Thanks guys for the replies and nice pictures from Dwight. I was considering doing the bend thing if necessary,my cover is long enough to cover the discoloration. Greg I have different seats than you (i think) mine are more round in the back and my arm is very close from the seat's edge because of that when I shift and my arm feel a little high because of the shifter lenght,i will have to drive it to see if it's too close. I have to take it for inspection,it's ready but I don't have time now,all I do is drive it around the crescent,not enough. Work in progress !!
Michel
Old 08-16-2010, 06:22 PM
Cashburn's Avatar
Backdraft Racing Dealer
Cobra Make & Engine: Backdraft Racing
Our favorite with the TKO flipped in the rear position...
http://www.vintage-motorsports.com/store/index.html
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 08-16-2010, 07:17 PM
Mac VABCH's Avatar
Cobra Make & Engine: BDR #250
Default Remote shifter linkage
If you are using a road race type seat this remote linkage will mount to any shifter. Moves it forward about 12-14". Also give a more horizontal shift pattern. Mac
Old 08-20-2010, 04:18 PM
Cobra Make & Engine: dd cobra,351w mild cam
Michel,I made my own...I took apart an old shock that had about a 1/2"thick shaft and had a threaded portion at the top,welded a tab at the bottom,drilled two holes to match the threaded hole in the T5 stub,put a bend about 1 5/8" up from the top hole...from there it is 5" to the bottom of the threaded part and put a shift nob that was on sale from Canadian Tire...presto...chrome shifter...half an hour making it and five bucks for the nob...works great!!!
Steve
Old 08-21-2010, 03:59 PM
SF_SN888KE's Avatar
not a T-5, but a follow up picture of my Jordon Short track shifter on TKO 600 mid shift kit location
notice offset towards the driver
Ron; SF_SN888KE
Old 08-22-2010, 12:50 AM
henrik's Avatar
Cobra Make & Engine: BDR 602 , polished Roush 427 sr/tw - Dynatek EFI polished 8 stack
Default Steeda tri-axe
I'v got the t-56 - picture will show the shifter
the link is for t-5
http://www.steeda.com/products/steed...emec_t5t45.php
http://clubcobra.com/forums/showthread.php?t=105090
BDR 602/Roush 427/EFI 8 stack/T-56 Magnum/540whp+750Nm (sold )
Old 08-22-2010, 02:42 PM
Default Shifter ??
Thanks guys for the pictures,I will have to assess the situation and see if I will use my shifter and modify it or replace. I might bend it,still thinking about it,cheers !
Michel
Old 08-22-2010, 02:59 PM
FUNFER2's Avatar
Cobra Make & Engine: 1966 Lone Star 427SC.
Question- just like the original shifter turned forward, just how hard is it to get used too ?
Especially,..... 2nd to 3rd.
Kevin
