Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 06-24-2012, 07:06 AM
Default 51 ida's
Was wondering if anyone has tried this modification and if its worth it?
Old 06-30-2012, 03:22 AM
Gaz64's Avatar
Here's some info:
JayCee enterprises - Â WEBERS BY JAYCEE
GeneBerg.com Parts Catalog: Berg IDA Carburetor Sizes
http://www.geneberg.com/images/IMG_3118%20(Small).JPG
Gary
Old 06-30-2012, 06:43 AM
Gary,
Thats where I first read about the 51ida's. Was just wondering how well the work on an FE engine compared to say the 48's. Is there any loss of bottom torque?
Old 07-07-2012, 12:51 PM
Rick Parker's Avatar
Go for the 58's.
Rick
Old 07-07-2012, 04:33 PM
Gaz64's Avatar
Engine capacity in combination with cam/heads/compression etc determines venturi size.
Throttle butterfly size should be 20% larger than venturi.
In the ideal world, the inlet tract should be the size of the inlet valve.
The venturi is then about 85% of the barrel size, the valve throat is also about 85% of the valve diameter.
The 58s would allow a venturi of about 46-47mm, if your engine needs this much.
I've seen quad 58 DCOEs with 47mm venturis on a 427 race engine.
Gary
