Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 11-20-2014, 10:41 AM
Cobra Make, Engine: spf 2112 *427 stroker windsor
Default weber fuel log
Why did they weld fuel log on top of rad plumbing?
What im getting at is wouldn't the heat from rad plumbing migrate into fuel log thus heating the fuel before it even gets to carbs.
Always thought important to keep fuel cool.
Old 11-20-2014, 10:57 AM
CompClassics's Avatar
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
It worked...
Old 11-21-2014, 07:18 AM
bump bump bump
Old 11-23-2014, 03:07 PM
zrayr's Avatar
Cobra Make, Engine: Fords
It did work, and is still working. You're right of course, although it is more important to keep the air cool (more dense). As long as the fuel isn't close to boiling, it'll do.
It's important to remember, we're talking 1962 here. And the racing Cobra WAS good enough to trounce the bow wow, errr, I mean bow tie competition. That is what counted.
Z.
'65 K code Mustang
'66 Galaxie 500
Old 11-23-2014, 03:35 PM
*13*'s Avatar
Not the best design. As long as you keep the fuel flowing, it doesn't heat too much. Stop for lunch & that radiated heat gets into the fuel. I cut a couple holes in my uprights & it helps a bit. Remember, these cars probably ran until the race was over. You can also run a return line to the tank to keep the fuel flowing.
ERA FIA 2088
