Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree5Likes
  • 1 Post By talos
  • 1 Post By 1795
  • 1 Post By talos
  • 1 Post By 1795
  • 1 Post By bobcowan
Old 09-25-2024, 02:55 AM
Gaz64's Avatar
Originally Posted by talos View Post
You will have to start with the cam. The LSA should be between 112-114. Compare that with your cam. Most likely you will have to change it. There is plenty of info on this forum, the web, and you tube. Do your research thoroughly. This will be a project but fun if done with patience.
That is a myth. The reason and pure coincidence of the camshaft timing is the opening and closing points of the intake valves.
For example, ending up with an ICL of 112, and generally with a LSA of 112, I can still have crazy intake valve timing of say 54/90? ICL of 112, LSA of 112.
I have run Webers on IR manifolds, one choke per cylinder, with cams right down to 105, and still have near EFI drivability. That was a 40/70 intake timing.
Since the OP says his engine idles nicely now, the cam mustn't be too wild.
Gary
