Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
Old 04-20-2026, 04:10 AM
Cobra Make, Engine: Just a collection of parts right now...
Send a message via MSN to spl310
Default General questions
Do Weber carbs require high compression or is 9.6ish OK? Will Webers perform OK with a solid lifter hipo reproduction cam?
Old 04-21-2026, 09:37 PM
Default No issues!
No, high compression is not a requirement. Like any setup, higher compression can be better........ but only if you have the right fuel!
They ran the old Ford cams in the races back in the day, and they worked to win the races, so why not? Many are running less cam than that with Webers successfully.
What is your engine setup?
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
