Old 05-07-2006, 03:11 PM
dlampe's Avatar
Default Weber issues - need opinions
When I rev the engine in the garage I have a pop in my sidepipes after about 2000rpm's. Maybe more on the driver side but the damn thing is so loud I really can't tell. What will cause this popping? I have sprayed carb cleaner around the intake but found no leaks. I think my fuel pressure is right at 2.5 and I think my timing is around 38 degs. This is a 408w.
idle jet 65
idle jet holder 120
primary jet 150
air correcter is 190
f7 tubes
50 exhaust valve and pump
37 venturi's
I am running rich around 11 to 12:1 A/F. That is not that far off. If that is the issue, what to change? That ratio is through the whole band.
The car runs pretty good already but I really hate to do to much road testing since it is not exactly legally registered yet.
High Maintenance Racing Team
Run & Gun 2003 - 2013
Old 06-14-2007, 06:41 PM
Rick Parker's Avatar
What did you determine was at fault?
Old 06-15-2007, 04:13 AM
dlampe's Avatar
I went to f16 tubes and corrected some carb balance issues. I got your PM, just haven't had time to get back to you but the chokes are OEM.
Old 06-15-2007, 05:49 AM
JCoop's Avatar
I assume you have 48 IDAs?
Popping usually means too rich; as opposed to sneezing, which would mean lean.
When this occured with my setup, I went lean on the idle jets (55s) and disconnected the distributor vacuum advance. Timed it to 38 deg. max and she's running great. Just a bit fat at idle but the transition is smooth and response immediate. You may want to go to the next smaller size idle jets, 60's maybe.
edit: This was on the GT40 w/ 302.
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
