Old 09-16-2007, 09:26 AM
dlampe's Avatar
Default Weber popping question
According to my A/F gauge, I am really lean when I let of the gas at all rpm ranges. I believe this to be the cause of the popping. What is causing this? I seem to be running lean on the mains as well but that is an easier fix.
For future reference,
Edited for current settings
65 idle jet
120 idle jet holder
170 main
210 air corrector
f7 tubes
.00 exhaust/ float bowl valve
40mm chokes
380 ci 302 with 8.7 deck, Yates heads with huge CFM numbers.
cam - solid roller dur. I 244, E 247 lift 631, 666 110 LCA 106.5 LSA
High Maintenance Racing Team
Run & Gun 2003 - 2013
Old 09-16-2007, 09:34 AM
ENTDOC's Avatar
how far out are the idle mix screws?
Old 09-16-2007, 09:44 AM
dlampe's Avatar
They right at 3/4 turn.
Old 09-16-2007, 09:52 AM
ENTDOC's Avatar
I realize that is the ideal turnout, but I would try 1 full turn and see what happens, if it helps then going up in the idle jet may be in order. On the other hand if it works and the A/F is good , then leave it out. I have found that when you are dealing with more exotic motors you have to fudge on the conventional wisdom with webers.
Old 09-16-2007, 10:04 AM
Full Throttle Al's Avatar
Cobra Make, Engine: CSX4083, NOS 427 SOHC, serial number 589. Dyno'd in 1967 at 629HP with single 4v 560 Holley. Now with 4 Webers.
This article at Inglese Inductions helps to understand the Weber carb and its problems and fixes, I found it was a good place to start:
http://inglese.com/tech.htm
Old 09-16-2007, 10:05 AM
ENTDOC's Avatar
that is a good article but all bets are off with Deans motor as well as a stroked 427
Old 09-16-2007, 08:40 PM
Cobra Make, Engine: ERA #122 (Sold) : Ford GT #484 Heritage Edition; 2008 GT500 Red/Black
Dean the best suggestion I can give you is to put the thing on a dyno and tune it. It will save you alot of heartache in the end.
Depending on what your doing with the car I wouldn't run the 40's they will just make tuning it that much harder. If your going to track the car only then set it up for that..if your going to drive it on the street then have either 2 configs or just run the street setup. If you remember David's Kirkham we only had 37's in it and didn't have any issues with fuel. THE DYNO will save your sanity.
The biggest problem is finding someone that has a slew of jets so you can set it up while tuning it.
Old 09-17-2007, 05:46 AM
dlampe's Avatar
Jac Mac, the popping is coming out of both pipes. It really doesn't sound like it is at the intake. My A/F gauge is reading lean not rich during the popping. I am going to try some smaller correctors.
Matt, you said harder to tune, not impossible, right! I am going to start changing a few things and see what happens. My timing is set at 32 deg. locked at the dizzy. Should i bump that or or does it matter as far as the weber tuning goes?
Old 09-17-2007, 02:07 PM
Jac Mac's Avatar
>>>> >>>>>My timing is set at 32 deg. locked at the dizzy. Should i bump that or or does it matter as far as the weber tuning goes?<<<<<< <<<<<
UMMMM Deane This locked timing wont be helping in an over run or coast situation ( or even if you try to accelerate particularly if your down below 2500 RPM ). I must repeat that you are asking the carbs & motor to do something it doesnt want any part of !
Jac Mac
Old 09-17-2007, 02:51 PM
PatBuckley's Avatar
Shirley on the race track you would never be below 3- 3500 RPM?
Old 09-17-2007, 04:07 PM
Jac Mac's Avatar
Smile
Yes Pat, but when I went back to Deanes build thread I noted that he has a dual fuel setup for pump & race fuels and this 'popping' condition he is trying to solve is apparently in the coast mode right down thru the RPM range. I get the impression that he is asking the motor to perform in 'road' mode while it wants to be a 'race' motor. You wont find any current computer controlled road car that has the ignition permanently locked at 32° and a 'fixed' fuel distribution device that can work to maximum performance under all conditions with both fuels.
Also with 40mm chokes the airflow will fall well short of the heads capabilities on this motor.
Jac Mac
Old 09-17-2007, 08:29 AM
Rick Parker's Avatar
"Timing Locked @ 32 degrees" (??) Do you mean "limited", or is it running fixed 32 degrees all the time?
Old 09-17-2007, 12:01 PM
zimmy's Avatar
Cobra Make, Engine: Contemporary, 427 FE Center Oiler w/ 48 IDA Webers
Send a message via AIM to zimmy
A locked timing may be okay for racing where you are mostly wide open but I think that you would want variable timing for the street. I know Webers like a lot of timing. I'm not sure about your engine, but for my stroked 427 FE I run 17 deg initial with 21 degrees advance for a total of 38 degrees. The advance comes all in by 2800 rpm. I believe that this will help your popping issue as well.
I have been told that exhaust popping comes from an exhaust leak for sure, but that it is also worse when leaner than when rich. If you are going lean when you decel this will make the problem more pronounced.
A lean condition makes for a very poor wave front in the combustion chamber causing an inefficient burn and a fair amount of uburned gas to be left over. This unbured gas hits your hot headers and expoldes causing the pops. Your advanced timing when on the idle circuit (under hard decel with your foot off the pedal) will make the unburned gas issue even more pronounced.
Old 09-17-2007, 05:01 PM
Dean: If you are running fixed ignition of 32 degrees on the street you'll knock the ring lands out of the pistons. I've seen it done. Be very careful.
Old 09-18-2007, 07:45 AM
dlampe's Avatar
I have my timing locked at 32 deg. That is correct, but only for the track. I have a switch to change ingnition systems to a computer that will advance the timing up a normal curve. I have another switch to retard total timing 3 degs. I was just trying to tune the race system. I will admit that I haven't tried running hard on the street timing system.
I did up my idle to 1000 rpms and I backed out my mixture screws to 7/8 out. The popping wasn't there. My engine will not idle as low as many due to the very light wieght rotating assembly. If the race idle is set at 1200 for the track, the idle falls below 900 when I flip the timing switch and go to the street system. I think that would be okay. I have ordered some 190 Air correctors and 180 mains just to see what happens. The popping has gotten a lot better, almost gone. I am still lean any time I am close to WOT.
Old 09-18-2007, 09:05 AM
Brent Mills's Avatar
Administrator
I did up my idle to 1000 rpms and I backed out my mixture screws to 7/8 out. The popping wasn't there. .
Are you running rich at idle now because of this?
Old 09-18-2007, 09:14 AM
ENTDOC's Avatar
the idle mixture screws almost always correct the popping problems. Dean, I would drop the air correctors first before I went up on the mains, this will affect the WOT the most and mid throttle the least.
Old 09-23-2007, 07:00 PM
dlampe's Avatar
Well it is getting much better. However it is really lean from 3000 to 4500 under hard acceleration. It looks like the pump kicks in at 3000 and takes the A/F down until 3500 rpm's from a spike of 18 when the plates open to 14.5 then it looks like the pump shot is over and it goes back up to 18 then gradually back to 12.5 all the way to 6500rpms. It takes 5 seconds for this to happen from the throttle plate opening to get the A/F down to 12.5. It takes 2 seconds for the Pump shot, 1 second to climb back to 18 then 2 more seconds to come back down.
Here is how it was set up
70 idle jet
120 idle jet holder
170 main
210 air corrector
f16 tubes
40mm chokes
50 pump shot
It was way lean at the top end so I went to 190 air correctors and thats when it got the results that I described above. The car seems to run good but I need to fix the lean spot between 3000 and 4500. I was thinking about going to 180 mains and putting my 210 air correctors back in. Any other thoughts?
