Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
Old 09-30-2007, 02:49 PM
ENTDOC's Avatar
Default cam choice
I am going to change from a hyd flat tappet to a hyd roller in my GT40. It has a 302 with alum SVO heads and I am putting the webers on. Any suggestions for a good cam choice? thanks
Old 10-02-2007, 09:50 PM
Rick Parker's Avatar
What do you hope to gain from the change? If you are doubting your current choice, try a
Crane # 363841 Solid lifter Flat tappet.
Good with Webers.
Rick
Old 10-02-2007, 10:27 PM
what hyd roller cam will you use?
Old 10-03-2007, 03:27 AM
Naumoff's Avatar
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
Chuck,
Make sure you get a cam that has nice firm lumps on it that won't overlap
with a duration of about a 20 year old. Not to wild now. Don't want you having a heart attack from all that pull.
Old 10-03-2007, 07:54 AM
I like the ford racing f303 cam. It pulls hard in the mid range and up top. It is the turbo cam of choice for many. " http://turbomustangs.com/ " It would be very obvious your engine is not stock.
Old 10-03-2007, 08:52 AM
bobcowan's Avatar
Need more information. Simply asking "what's a good cam" is like saying, "I have to fix my car, what tool should I use?".
Street performance, drag racing, road racing, good mileage cruising? Makes a differance.
Old 10-03-2007, 10:08 AM
ENTDOC's Avatar
mostly spirited street driving. I am mostly concerned that the cam be weber friendly.
Old 10-03-2007, 05:21 PM
bobcowan's Avatar
You can use pretty much anything you want in that catagory. Individual runners like a little more LSA, but that's not a big deal. Stay with at least 110*. if you have the option of 112*, use that.
