Old 10-23-2007, 05:44 PM
Rick Parker's Avatar
Default Hood clearance for Webers
I have noticed since I installed the Webers that when I shut the hood after tweaking them, the idle drops a little. I didn't give it much thought until today. I have been chasing an irregular very slight miss that I hear while cruising at 2800 RPM and above. Today I started thinking about the hood scoop opening cut into the hood. I took some measurements and it appears that the leading edge of the hood opening under the scoop is straight accross the center of the Carb stacks on each of the two front carbs and about 1/2" or less above the stack itself. After giving it some thought maybe this is causing very poor airflow for the two front Carbs. I think I wll relieve the front edge of the scoop opening by about 2 1/2" and radius the corners. The width is 11" which seems like more than enough.
Comments
Old 10-23-2007, 05:47 PM
ENTDOC's Avatar
I did the same on my Kirkham Rick, seemed to help
Old 10-23-2007, 06:09 PM
lineslinger's Avatar
Thought you were going fishing??!!
