Like Tree2Likes
Old 09-30-2009, 02:57 PM
Stentor's Avatar
Default 58 mm Berg IDA Carbs--Here They Are
Well, Berg finished my 58 mm IDA carbs today. Now I've got to get them assembled, on my car, and dialed in--the journey begins.
If I can get them to run half as good as they look I should be in good shape.
Old 09-30-2009, 03:10 PM
cobrakiwi's Avatar
very nice, I want some!
Old 09-30-2009, 04:36 PM
Full Throttle Al's Avatar
Cobra Make, Engine: CSX4083, NOS 427 SOHC, serial number 589. Dyno'd in 1967 at 629HP with single 4v 560 Holley. Now with 4 Webers.
Stentor,
Very nice! You need to make sure the stock hood scoop is going to work, you may need to get the extra wide version sold by Cobra Restorers in aluminum. See my gallery for pictures. In 12 years, no one has commented to me if they noticed any difference when looking at the car.
Old 09-30-2009, 04:39 PM
I posted this in the other Weber threads but wanted to make sure you saw it, my reply from Berg:
Mr. Sorkey, Our Berg IDA carbs have the same stud pattern as the original Weber 48 IDA. The top of the intake manifold needs to be opened up for the larger throttle plate in our carbs.
Sincerely,
GENE BERG ENTERPRISES
Tim Walker
Parts Manager
Old 09-30-2009, 06:19 PM
*13*'s Avatar
Great carbs! Get them installed!
ERA FIA 2088
Old 09-30-2009, 07:50 PM
Stentor's Avatar
Sincerely,
Tim Walker
Parts Manager
Al,
Thanks for posting the message from Berg. I have confirmed that the standard 48 IDA FE manifold will work just fine (consistent with the message you received). I have already had the machine work done on the manifold to match the Berg 58 mm carbs.
Thanks for the heads-up regarding the hood scoop. I went with the shorter velocity stacks to try to help with hood clearance. However, the diameter of the stacks is almost 4" at the top--so they're pretty wide.
I will keep you posted as I try to get things together over the next couple of weeks.
Stentor
Old 10-01-2009, 10:31 AM
How much machine work was required to fit the 58's? Can you post a photo of the finished manifold?
Thanks.
Old 10-01-2009, 11:23 AM
Snakebit's Avatar
WOW those things are huge! You will have to post a sign at car shows "DANGER, when engine is running small dogs and children may by sucked into the intake scoop"!
Snakebit
Old 10-01-2009, 05:28 PM
Stentor's Avatar
Thanks.
Al,
I don't have a picture of the finished manifold yet--I will post one as soon as I can. I have been told that the manifold came out fine--and I believe the machining cost was around $200 to $300.
Stentor
Old 10-08-2009, 05:13 PM
Stentor's Avatar
One step closer--now I've got the 58 mm Berg IDAs mounted on the manifold and ready to go.
Old 10-08-2009, 05:31 PM
Banned
Dayum! Better keep small animals from getting sucked into your hood scoop.
BTW, they look great on that intake.
-Dean
Old 10-08-2009, 05:32 PM
*13*'s Avatar
Bellissimo! Works for me! Get her mounted up!
ERA FIA 2088
Old 10-08-2009, 08:27 PM
RodKnock's Avatar
They're so big, that if they were white, I'd have to pee in them.
You have me thinking Webers now, though mine would be the bidet-sized 48's.
Old 12-07-2009, 04:59 PM
RodKnock's Avatar
Stentor, any updates? Do they fit under the hood? If so, what mods did you have to make?
Old 12-07-2009, 05:35 PM
Stentor's Avatar
Rod,
I did get the 58 IDAs in the car and am working on getting the carbs fine tuned. So far so good.
With the angled manifold and short velocity stacks it doesn't look like I am going to have any hood clearance issues.
I will keep folks updated as I fine tune them over the coming weeks.
Here they are in the car.
Bill D likes this.
Old 12-08-2009, 10:15 AM
RodKnock's Avatar
Just awesome. Good luck with the tuning and I can't wait to hear about your driving thoughts. Please do update. Maybe down the road, I may go for some Weber 48's, not sure yet.
Old 12-08-2009, 11:12 AM
looks awesome
have you said bye bye to you tires?
Old 12-08-2009, 03:06 PM
Bluedog's Avatar
Cobra Make, Engine: Once Owned CSX4803, CSX803 block, Keith Craft 468, Suspension by Tom Barnard, Built by Kris Kincaid
Default Re:
Those are sweet!
Bluedog
Old 12-01-2013, 06:52 PM
Rick Parker's Avatar
How did these work out after being dialed in? They sure look great!
Old 12-05-2013, 05:39 PM
Stentor's Avatar
Rick,
Thanks for your message. I haven't been on the forum much lately (busy with work).
I have been very pleased with the Berg 58mm IDAs. It took a while to get them dialed in; but, once tuned they've been great (no problems or issues so far). And the 58s work nicely on the bored/stroked FE.
Best,
Kevin
