			|  Main Menu |
			|  Nevada Classics |
			|  Advertise at CC |
			| S | M | T | W | T | F | S |
			|  |  |  | 1 | 2 | 3 | 4 |
| 5 | 6 | 7 | 8 | 9 | 10 | 11 |
| 12 | 13 | 14 | 15 | 16 | 17 | 18 |
| 19 | 20 | 21 | 22 | 23 | 24 | 25 |
| 26 | 27 | 28 | 29 | 30 | 31 |  |  |
			|  CC Advertisers |  |
				11-16-2010, 08:47 AM
			|  | CC Member
						IL Cobra Make, Engine: Backdraft#357, 392CI Ford Racing, 459hp, 455ft/lbs  , TKO 500, 3.43 Gears, Ceramic Coated Headers, Victor Jr. 750cfm, 17in Halibrand wheels, Sterling Gray/Silver Stripes, Gray Leather, Nitto NT05
	|    Not Ranked
				 This Spinner Tool works great! Leather Wrapped
    We just used this for the first time, it's fantastic.  Just like with a hammer, you can feel the spinner hit "rock bottom" and "hit back".  No broken spinners or no dings in the aluminum wheels. The padded leather is nice too, no scratches on the spinners.  I know you lead hammer and wood guys are sold on your method, but for the less bold, you should check this out.
http://knockoffspinnertool.com/
(See the one for the cobra, not the Jag or Lotus...)
				__________________1/4 mile 11.92@115.6 and 60ft 1.632
				11-16-2010, 08:57 AM
			|  | CC Member
	|    Not Ranked
 In my opinion:Nothing beats a nice Lead hammer and a little experiance using it...
 Proper spinner maintenance, occasional removal and inspection, and not over-tightening are the keys to easy removal...
				__________________Wiring Diagrams: SPF MKII, MKIII, GT40, CSX7000, CSX8000, Corvette Grand Sport, and Shelby Sebring,  Bondurant & Cinema Tribute Cars. Owner’s Manuals: SPF MKII, CSX7000, CSX8000, Sebring, Bondurant, Cinema Tribute Cars $ GT40’s..
SPFWiringDiagrams@Comcast.net			 Last edited by Blas; 11-16-2010 at 09:00 AM..
				11-16-2010, 09:08 AM
			|  | CC Member
	|    Not Ranked
				 Blas
 I'm not disagreeing with you.  But for me, this is idiot proof - and if you have ever seen me try to fix something - you'd know why that is valuable to me.  I could do this now without a torque wrench because the feel is just as easy as a hammer.  I'm not suggesting this is better than the tried and true hammer method, but it eliminates the mistakes and damage.  I'll let you try it if you want, it made a believer out of me.  It is no "paperweight" as someone described another tool.
				11-16-2010, 10:45 AM
			|  | Senior Club Cobra Member
						CT Cobra Make, Engine: SPF - 351W, 944 non-turbo
	|    Not Ranked
 What is the proper torque for a spinner?
 Based on my experience removing these guys, you better have a very long breaker bar. I will say though, if I had one in the garage I would probably use it.
				11-16-2010, 01:38 PM
			|  | CC Member
	|    Not Ranked
				 Torque specs
 I have not found torque specs for Cobra spinners, but the guy invested the tool said Lotus, in an old manual, recommeded 220 ft/lbs.  That's about the only source I have heard quoted.  I am not sure why it would be different for Halibrand knockoffs, but I wouldn't make a recommendation.
				11-16-2010, 02:23 PM
			| CC Member
					Join Date: Apr 2008 Location: Near Chichester, Sussex by the sea......,
						UK Cobra Make, Engine: Crendon 427 S/C 428 FE+toploader
	|    Not Ranked
				 spinners....
 theres an old thread on here discussing how to to do this somewhere, but cant find it. |
				11-16-2010, 02:54 PM
			|  | Half-Ass Member
					Join Date: Jun 2005 Cobra Make, Engine: ERA #732, 428FE (447 CID), TKO600, Solid Flat Tappet Cam, Tons of Aluminum
	|    Not Ranked
					Originally Posted by Jimbocobra  ... in an old manual, recommeded 220 ft/lbs.  That's about the only source I have heard quoted.  I am not sure why it would be different for Halibrand knockoffs, but I wouldn't make a recommendation.  |  Now I don't know (and I use a lead hammer), but 220 ft/lbs sounds like a whole lot to me.  Having torqued my crank bolt down to about 110 ft/lbs this summer, I think 220 would be a real b****.  |
				11-16-2010, 05:46 PM
	|    Not Ranked
 The lug nuts on my Focus call for 95 Ft-Lbs. 220 on that one big guy doesn't seem so unreasonable.
 Porsche calls for 340 FT-LBS on their hubs.
				11-17-2010, 08:25 AM
			|  | CC Member
	|    Not Ranked
				 Torque
 The mechanic who is helping me with my car said he used the hammer method to put it on, then a torque wrench in reverse and it came out to about 75 ft/lbs.  I told him about the 220 number and he said "no way", it is obvious when you can't move it anymore and is easily confirmed with a hammer.  I will test it tomorrow again when I pick up the car and post the results.
				11-17-2010, 10:21 AM
	|    Not Ranked
 Iron hammer, piece of wood... |
				11-17-2010, 10:30 AM
			| CC Member
						wi Cobra Make, Engine: ERA #726 427 SOHC
	|    Not Ranked
 Torqued my spinners to 65 lb-ft. Haven't moved in 3 yrs according to the safety wire. I check them before every drive. |
				11-17-2010, 10:46 AM
			| CC Member
	|    Not Ranked
 This appears to be a well-engineered alternative to the tried-and-true "beat-'em-on, beat-'em-off" method.  Possibly for someone that isn't good at driving a nail with a hammer, but for most the old school method seems to work fine.  To each his own. |
				11-17-2010, 01:33 PM
			|  | CC Member
					Join Date: Jul 2005 Location: Carpentersville,IL & Maricopa,,
						AZ Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
	|    Not Ranked
 Like THEY say, "ya can't teach an old dog new trick!"
Ralph
				__________________SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE  SPOT Burma Shave
				11-17-2010, 01:57 PM
			| CC Member
						.. Cobra Make, Engine: UK Ram SC. KC-Yates 373, Jerico 5 speed.
	|    Not Ranked
				 Spinner tool
					Originally Posted by elric  Torqued my spinners to 65 lb-ft. Haven't moved in 3 yrs according to the safety wire. I check them before every drive. |  I would feel a bit uneasy about leaving wheels on for that time and I would definitely use anti-seize.
I dont see the point in the leather on the tool all that does is soak up force and feel, the spinners are forged 6061 T6 the spinners should handle a snug well designed tool twisting on them.  Good idea to avoid excess damage to the spinner.
				__________________A J. Newton
 The  1960's rocked!
				11-17-2010, 02:19 PM
			|  | Half-Ass Member
	|    Not Ranked
				 Steel, please...
					Originally Posted by Ant  Good idea to avoid excess damage to the spinner. |  Perhaps with those wimpy aluminum spinners... but with steel spinners, you can whack them, drop them, throw them, and even dance on them and you ain't gonna damage them -- and the patina is quite fetching.    And you can forget about ever breaking an ear off.   			 Last edited by patrickt; 10-27-2016 at 09:11 AM..
				11-18-2010, 09:57 PM
			|  | CC Member
	|    Not Ranked
					Originally Posted by patrickt  Perhaps with those wimpy aluminum spinners... but with steel spinners, you can whack them, drop them, throw them, and even dance on them and you ain't gonna damage them -- and the patina is quite fetching.    And you can forget about ever breaking an ear off.    |
That's the way to go... |
				11-19-2010, 04:22 AM
			|  | Half-Ass Member
	|    Not Ranked
					Originally Posted by Bxx1  That's the way to go... |  Yep, stainless steel spinners -- makes for a great stocking-stuffer.  $320 in satin finish, or $400 for the polished.  http://www.cobraracing.com/ProductsPages/wingnuts.html |
				08-22-2019, 02:17 PM
			| CC Member
	|    Not Ranked
 Anywhere else this tool can be purchased at? |
				08-22-2019, 03:43 PM
			|  | CC Member
						CA Cobra Make, Engine: CSX 6079 482CI CSX cross ram
	|    Not Ranked
 If you are needing to hit your spinners so hard that you are damaging them than you are putting them on to tight... |
				08-22-2019, 04:03 PM
			|  | CC Member
						AR Cobra Make, Engine: ERA Street Roadster #782 with 459 cu in FE KC engine, toploader, 3.31
	|    Not Ranked
 I'm a little concerned over some of these spinner adaptors being used with a breakover bar.  I know on my 66 Corvette the factory torque design for the hub/spinner is 450 ft lbs.  I would suspect it's not much, if any less for a Cobra hub/spinner.  That takes a pretty long bar for the average person to get that high.  A good pneumatic impact gun with an adaptor would get there.  Of course no one knows how tight a 6 lb lead hammer gets it without some testing but I suspect if your tighten them until you hear the sound of the hammer blows distinctly change to a hard metallic sound - it's pretty high. |
	|  Posting Rules |
		You may not post new threads You may not post replies You may not post attachments You may not edit your posts
 |  |  |  All times are GMT -7. The time now is 05:57 PM.
