Go Back   Club Cobra > Club Forums > Windy City Cobra Club
Old 09-10-2011, 02:51 PM
Cobra Make, Engine: Street Beasts/5.0 Jon Barrett Hot Rod Engine
Angry Headlight issue
Guys...my headlights went out on the way home from volo last sunday. when i turn on the swith i get just a flicker and they immediately go off. i can hear the breaker trip as lights flicker for that split second. i tried a new switch,new breaker and checked bulbs...none burned out...lights are not wired to a relay but run thru the 30 amp switch...original builder of the car used steering column from early 80's camaro so dimmer works from turn signal stock...could a bad dimmer switch in the column cause a problem like this?
any input will be welcomed.
Thanks.
Jerry
Old 09-10-2011, 03:01 PM
charles roybal's Avatar
Cobra Make, Engine: FRR MKIII 408w
Run then through a relay.
Charles Roybal..."Drive with your lights on!!!!"
Old 09-11-2011, 05:30 PM
Charles...thanks for the response...I was thinking that might be something I should do.
Old 09-11-2011, 05:47 PM
bobcowan's Avatar
If they worked before, and don't now, then clearly there's a problemin the existing circuit. Adding a relay circuit isnt' going to fix your problem. You'll have to trace the circuit from one end to the other and find the problem. But I would start in the 31 year old steering column.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 09-14-2011, 10:55 AM
Thanks Bob...in the process of doing just that.
