12-10-2003, 03:40 PM
IL
Cobra Make, Engine: SPF 1454
1/4 mile times/mph
Has anyone run their cars at the strip (1/4 mile)? If so, what times/mph are you running. What's your vehicle type, engine setup, trans, and tires. Just curious.
CHRIS
12-10-2003, 03:58 PM
IL
Cobra Make, Engine: SPF #1507 427 Dart Block Windsor
Car is similar to yours, with a Performance Engineering 418.
Second gear launch, still trying to figure out how to do this without spinning the tires so badly.
If you're interested, the Windy City Cobra Club has a couple of events at Byron Dragstrip in the summer.
12-10-2003, 04:16 PM
NM
Cobra Make, Engine: West Coast Cobra weber fuel injected 557 C.I.. 800H.P 760LBS. TQ. Magnum T56
SO I WAS TOLD!!!!!
When Carl Robison of WELD MOTORSPORTS owned my car he said it did 8:90's with slick on but i have not confirmed this myself! He said it was just uncontrollable with street tires.BUT I WILL COMFIRM THIS SOON!!!!
WHEN YOU HAVE MORE HORSEPOWER THAN YOU NEED ITS STILL NOT ENOUGH!!!!!!!
12-10-2003, 05:44 PM
SC
best was 12.0 at 119, SPF, stroked 392 Windsor, stock Goodyears GTII's. But it was a cool fall night, and i short shift to second,, leave the line just above idle, shift, and get hard on it.
But i usually run about 12.3 -12.5 at about 115, when warmer. Very traction limited, of course.
Hal Copple
Stroked SPF
"Daily Driver"
IV Corps 71-72, Gulf War
12-10-2003, 05:52 PM
Il.
Best time slip so far 11.71 aprox 114mph.
3.8 V6 turbo automatic  street tires, cool day
12-10-2003, 06:39 PM
ks
Premier built Kirkham hybred,
289body/427 chassis/ blown4.6dohc
2 gear launch / 60 ft @ 1.96
11:23 @ 133.6mph
still not hooked up, mph says low 10:0's or high 9:90's
12-10-2003, 07:03 PM
IL
Has anybody tried the bfg drag radials? I wonder how much of a difference they would make? I haven't had my car to the track yet but I can't get any traction with the bfg t/a's 295/50/15 on the street.
CHRIS
12-10-2003, 07:51 PM
Ky
Cobra Make, Engine: CSX4761, KCR Shelby Alloy 496,760hp
my son in law has the bfg radials on his mustang,5.0,gt40 heads,victor upper and lowers,vortex s trim,,its about a 7 second car,,
even with lots of suspension work it spins the radials at will,,around the street racer clan here,,they say Mickey Thiompson makes the best street slick,,Tim
Tk
"this whole Adult thing just isnt working for me "
12-10-2003, 08:10 PM
MA
Cobra Make, Engine: FFR 1496 289 hi-po.
Best so far 10.74 @123
Hoping for 10.50's in 2004
FFR with 289 No power adders. But with slicks.
Brian
Qwik 1 289/tremec/10.74@123/normally aspirated
12-10-2003, 08:55 PM
Cobra Make, Engine: FFR: 302 w/aluminum heads, Edlebrock injection. Street car trim, no scoop, side pipes or rollbar.
<<5.0,gt40 heads,victor upper and lowers,vortex s trim,,its about a 7 second car,,>>
Can I assume that's 7 seconds in the 1/8 mile?
"Cobra-Cobra-bo-bobra, banana-fanna-fo-fobra, fe-fi-mo-mobra...Cobra!"
12-10-2003, 09:05 PM
11.89 / 120.5mph best to date.
392SVO Crate w/Trick Flow Twisted Wedge heads, AED Dominator 820cfm carb, Yoko Avids 295/50 on rear
12-11-2003, 04:43 AM
IL
Looking at these replies, it's obvious that the street tires are a huge obstacle to dragstrip performance; it appears that one of these cars with 450 +/- HP should easily run in the 11's, maybe 10's with appropriate tires and good technique. It's certainly tempting to spend a few hundred bucks for a set of drag radials, add a line-lock and a shift light and see how low I can get. My guess is that that should be worth a second or so. On the other hand, what I DON'T want to do is start down the path to turning this car into a dragster. When I get my car into the 11's, I'll be happy. Hal, I like your idea of coming out easy, then getting on it, although I still should be able to start in 2nd and save the 1-2 shift time. I was able to run the auto-X at Spring Fling in 2nd and felt the car had plenty of torque to take off without hesitating. So maybe come out easy in 2nd, then nail it is the key to the 11's. Too late now to find out, though; we have snow on the ground here in northern IL.
12-11-2003, 05:26 AM
Drag racing your car puts undue stress on your vehicle and may lead to socially unacceptable behavior. I would not sugest you engage in such activities
12-11-2003, 05:44 AM
>>Drag racing your car puts undue stress on your vehicle and may lead to socially unacceptable behavior. I would not sugest you engage in such activities<<
Hey Chifo, you forgot the part about the hug sh!t eating grin! javascript :smilie('  ')
12-11-2003, 03:48 PM
IL
Lowell,
Did you go to Byron with the rest of the club this summer? I plan on going this year. I just got my car in October this year.
I'm also thinking of purchasing a set of drag radials in the spring, I'm just curious how they will affect the cornering of the car?
CHRIS
12-11-2003, 06:08 PM
IL
Chris,
I participated in two WCCC events at Byron Dragstrip last summer and fall. It would be great to have more folks show up next summer. I think we had maybe 8 or so cars at the better-attended of the two events, so the more, the merrier! If I were going to run drag radials, I think I'd put them on a spare set of wheels and just use them for drag racing.
12-11-2003, 07:08 PM
IL
Great feedback so far. Anybody else run at the strip?
CHRIS
12-12-2003, 05:01 PM
Il.
Hey Chris
Erik has just got a set of those the end of this year .
Last I talked to him about it ,
He said that it made a big difference
I was thinking of going with Nitto's .
We will see next year everybody should have their cars tweaked pretty well.
12-12-2003, 07:03 PM
Cobra Make, Engine: FFR2100X (Mk1) - Whipple Blown 331
Took the Cobra to the strip for the first time in November. Ran 12.17 @ 111, 11.85@116 and 11.84@115. Thats on street tires (Bridgestone Potenza RE730's). Drove in and ran without even opening the hood. Car has 3.08 rear gears and only 362 dyno'd RWHP. You guys with the big HP should be running 10's on street rubber no problems.
12-13-2003, 04:07 PM
IL
MJN,
Are you getting pretty good traction with those tires? What size wheels are you running. Any 60ft. times? What trans do you have. Impressive numbers on street tires.
Has anyone ever tried a slick?
CHRIS
