Go Back   Club Cobra > Club Forums > Windy City Cobra Club
Old 05-23-2006, 05:04 PM
jeffko's Avatar
Cobra Make, Engine: BDR #177 Carbed Ford Small Block
Even faster...especially if he takes some of Blas's advice.
Tis better to burn out than to fade away. So "Lite 'Em Up!"
Old 05-23-2006, 10:59 PM
ALSNAKE's Avatar
Cobra Make, Engine: Superformance,514BB
Sunday was a blast --- did not know what to expect from the snake, first time on the track(won't be the last!!!) and I have not taken a car the track since the 80's-----very happy overall just need to be more consistant
street tires 275/60R15 BFG TA
1st run 11.827@106.74mph
2nd run 13.237@111.20mph
3rd run 15.683@54.14mph
4th run 12.127@111.62mph
5th run 11.514@118.45mph
6th run 11.649@109.89mph
1st OK took easy-gain confidence(car & self)--2nd smoked tires off line and in second --3rd hooked up good and clutch sliped in second and third burnt clutch smoke came from under car coasted to end -- 4th see what happens all seems OK just make sure clutch is grabbing before punching gas-- 5th felt good, tires sliped in third -- 6th felt good, tires sliped in third earlier than last run
Things for next time carb tuning and be consistant, maybe drag radials
Al
Old 05-24-2006, 12:01 AM
Alsnake,
The mid 11 second times are interesting from the mph stand point. At 11.5 I would have expected to see well into the 120's (123-125) with a big block. The mph trap speed sounds more indicative of a small block, when considering the ET vs Trap Speed. A small block typically starts to 'run out of steam' toward the end, while a big block keeps pulling strong. I wonder if that big 514 could use some better 'tuning' for more top end pull? Perhaps it's leaning out a bit?
What rpm were you shifting at with your best run? Also with the T/A's I would expect your 0-60 ft time to be in the 2 second range as they are SO hard 'hook up'. If so, the numbers show some AWESOME power making up for 'lost time' outta the hole, while the lower mph leaves me scratching my head.
Could be a gear ratio effect, SO many variables with drag racing.
Good stuff...
Old 05-24-2006, 09:27 AM
Jerry Clayton's Avatar
Al's car was extremely rich on the high end.
Jerry
Old 05-24-2006, 10:27 AM
Hmmm, assuming there is enough 'fire' from the plug to light off the mixture I'd certainly rather run rich than lean. My 'gutt' tells me rich would not have as big an impact on trap speed\power at top end as lean would. Unless it's super rich to the point of having a big impact on h.p., I would think the extra fuel is simply 'blown out' the exhaust.
Old 05-24-2006, 04:37 PM
Bob Malmen's Avatar
All in all I am pleased to see an 11.9 on my first trip to the strip!!! For all the trash talk, all seems to normal now.
Time to paint the street!
Old 05-24-2006, 04:41 PM
snake oil's Avatar
Hey Ernie I was in the "Ilands" recently.
Do you all have an island thats flat enough and long enough for
a Drag strip?
The older I get, the faster I was........
So now I'm so fast apparently I appear to be standing still.
Old 05-24-2006, 09:54 PM
ALSNAKE's Avatar
Excailber,
my best run I shifted into fourth gear the rest were at rev limit in third at end of 1/4 --checked gear calculator and 6000 rpm in third is 112 mph -- need to shift in to fourth ---1/8 mi speeds 93.7-96.3 mph, 60' times 1.77-1.98 and 2.23 when spun tires off line ----- can't wait to go again I know I can do better
AL
Old 05-24-2006, 10:30 PM
RedSnake351's Avatar
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
a Drag strip?
Hey, RC, how did you know that EXCALIBER'S name is ERNIE?
Ralph
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
Old 05-24-2006, 10:36 PM
The road racing course, the roundy round dirt track and the drag strip were all CLOSED as of last month.
There is currently NO place to race ANYTHING on the Island of Ohau.
Ernie (sometimes I actually sign my name)
Old 05-25-2006, 07:03 AM
jeffko's Avatar
Ernie, great thread on your engine build. I hope it rains this weekend so I can kick back and read thru it.
