Go Back   Club Cobra > Club Forums > Windy City Cobra Club
Old 06-04-2006, 07:42 PM
Club Cobra Member
Cobra Make, Engine: SPF #1507 427 Dart Block Windsor
Chuck,
As above: clean 'em, check for proper mating, apply Loctite and reinstall. Dennis Olthoff suggested putting a little Chapstick on them from time to time. As long as they align properly, the Loctite should keep them from vibrating loose. Are there enough washers in the stack to let the two parts tighten onto the stack of washers or is the nut just tightening down onto the unthreaded part? Give me a call or an email if this doesn't make sense.
The SPF door latches really aren't up to the task. My big problems with them have been 1) the bearing surface sheared off one of the bolts, and 2) the flimsy handles bent in use. I faced off the backs of the bolts and added a piece of stainless steel to each bolt as a bearing surface and I made new handles, also from stainless, with redesigned cams and textured plastic knobs. I may have also added heavier springs at some point-can't recall for sure. Anyway, now they look great and work great.
Lowell
