Go Back   Club Cobra > Club Forums > Windy City Cobra Club
Old 06-27-2007, 09:57 AM
Poolw's Avatar
Cobra Make, Engine: SPF, KC 427
Default Tire Pressure
How many pounds of air pressure do you run in your tires. Provide your tire size and list street, track and drag air pressure.
I was running with 32# but have since learned that as a rule of thumb, no more than 1# per 100# of car weight. Now I run - --
Street - 22# rear and 25# front
Track - I don't do track
Drag - 18# rear and 25# front
To my Cobra: - - when I'm with you - Oboy!
Old 06-27-2007, 10:12 AM
RedCSX1's Avatar
Cobra Make, Engine: Shelby CSX 4766 (Vegas Built) with 482 Aluminum Pond motor
Good Year Eagles (Bill Boards) 25-27 for street and track.
Morgan LeBlanc
Fresno CA
Old 06-27-2007, 10:20 AM
Yokohama Avid S/T -- 28psi in the front, 26psi in the rear. Reasonably neutral handling.
Old 06-27-2007, 11:00 AM
w-lewis's Avatar
Cobra Make, Engine: Unique, 351W
Avids 24 F and R. Street use.
Old 06-27-2007, 12:28 PM
JBo JBo is offline
Cobra Make, Engine: Ex CSX3327, & AK7113 AutoKraft AC MK IV
Default pressure
dunlop sp8000's 255 x16 - 28 pounds
Old 06-27-2007, 12:58 PM
Cobra Make, Engine: LA Exotic
Warren;is that summer air or winter air
Old 06-27-2007, 04:02 PM
woody2's Avatar
Cobra Make, Engine: B&B 302ci
On my car max front 44 psi 235-60R-15
max rear 35 psi 295-50R-15 this max psi printed on the
sidewall of course this would give the best tire and gas mileage for
street use.
Old 06-27-2007, 04:20 PM
Dwight's Avatar
Smile Pressure
BFG G-Force 28 front and 24 rear street only. Best traction on wet and dry roads. Softer ride.
Dwight
Woody2
I think 44 & 32 psi is to much for our light cars on the street. Try 28 psi front & rear and see the differents. Better traction and softer ride.
Old 06-27-2007, 04:23 PM
Why are you guys running so much air pressure?? I tried all of the above and the most even tire wear and neutral handling came with 18# front and rear. Better ride, also. 245-60R-15 and 295-50R-15 Goodyear GT2's. Dynamic also recommended lower pressures.
Eric 1151
Old 06-27-2007, 04:51 PM
1985 CCX's Avatar
Tire pressure:
Good Year Eagles (Bill Boards) 23 rear - 26 front "cold" for street only.
Jeff
Old 06-27-2007, 05:50 PM
Cobra Make, Engine: Superformance, 392 W
I run with 22 pounds in both front and rear on the BFG radial T/A's that came on the SPF. 255 60 15 front and 295 55 15 rear. It seems to be a reasonable compromise between performance and economy. (Did I just use the word economy while describing anything that has to do with a Cobra? I am sorry!)
SPF recommends 18 for normal and 25 for performance driving, I have not dropped the pressures to 18 pounds yet, seems a little low to me. Experimentation will tell you what your car and you prefer.
Old 06-27-2007, 07:23 PM
SCOBRAC's Avatar
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
Mileage? what is this Mileage???
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
Old 06-28-2007, 09:07 PM
Cobra Make, Engine: Unique Motorcars 289 FIA, S. Automotive 354 stroker
26 front, 24 rear. 235/15/60 Pirelli P600 fronts, 275/60 Nitto DR rear. I also autox with the same pressure/tires with quite satisfactory results. (Here's a recent video I posted in another thread: http://www.youtube.com/watch?v=r3-x_6Tg6lQ).
For drag racing I lower to 20 psi in the DR's. Could probably go lower.
Old 06-28-2007, 10:46 PM
CHANMADD's Avatar
The max tire pressure on the tire sidewall is MAX air pressure ,not the recommended,anything above that is dangerous! A Cobra is a light car and even on the track 30 -32 is more than enough, for the street take the advise given above ,mid 20's
