January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 05-11-2009, 11:05 AM
sparks's Avatar
Cobra Make, Engine: #1459 w/460(sold)New(used),spf w/427s.o.(sold)
Default exhaust bolt torque
Installing my new ss exhaust. What should the 5/16 grade 8 bolts be torqued to ?(pipe to header).
Old 05-11-2009, 11:10 AM
Cobra Make, Engine: KMP532, KC427FE, TWM
I have never torqued header bolts, I have no idea how I'd get to many of them with a torque wrench.
In any case for the first XXX? miles they seem to loosen pretty consistently. I would just suggest checking them every 100 miles and snugging them up until the are no longer getting lose.. Tighten them while warm if possible. Make sure you use antiseize on the bolts.
Cobra: A weapon of gas destruction
www.KobraBytes.com
Old 05-11-2009, 04:31 PM
Seagull81's Avatar
Cobra Make, Engine: FFR3542K, 347 C. I., EFI, T-5, Miata Front Sway Bar, 3 Link, Red with White Stripes
I can't get anything but a box end wrench on most of my header bolts. I get as much torque on the bolts as I can. Then check them after a couple of heat cycles. If loose check again until they stay torqued.
Steve
Texas Cobra Club-Austin
July 2009 FFCars Picture of the Month
FFR3542K, 347, Holley Sniper EFI, T-5, 4 Wheel Discs, 3-Link, Miata Front Sway Bar, Red with White Stripes
Old 05-11-2009, 04:44 PM
392cobra's Avatar
6th Generation Texan
If you can get a torque wrench on them.....
http://www.coxhardware.com/usefulinf.../7_btorque.htm
Old 05-11-2009, 05:31 PM
Rick Parker's Avatar
If they are in aluminum heads only tighten them when they are cold. Don't over do it.
I should have read closer sorry........
Rick
Old 05-11-2009, 06:12 PM
TButtrick's Avatar
You need to "spot" torque them. First, put a wrench on the bolt. Then, pull as hard as you can until you see spots. You're done.
Old 05-12-2009, 08:35 AM
onefastmustang's Avatar
Cobra Make, Engine: CRII with a Stroked Windsor
Isn't the question on the bolts that hold the headers to the exhaust pipes and not the headers to the heads?
Old 05-12-2009, 01:19 PM
TButtrick's Avatar
Yes. That's the way it reads.
Old 05-12-2009, 02:48 PM
sparks's Avatar
Thanks, Did the spot trq........
Old 05-12-2009, 04:36 PM
TButtrick's Avatar
Is that your "sleeper" sparks?
