SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 11-20-2011, 09:07 AM
Default Recommended Transmission & Differential Oils
Transmission: TKO 600R (.82 5th)
Differential: Ford Alloy 8.8" w/3.27 limited slip
Just wondering what you guys are using to keep things running smoothly and minimize parasitic losses?
Old 11-20-2011, 10:13 AM
Cobra Make, Engine: SPF #298 427 FI
Syncromesh for the Transmission, Differential royal purple
Old 11-20-2011, 11:12 AM
Grubby's Avatar
Cobra Make, Engine: ERA 838
GM Syncromesh is the suggested trans fluid. The manual does suggest a break in procedure with Dexron.
John
Old 11-20-2011, 01:01 PM
Thanks for the input guys, appreciated.
Old 11-20-2011, 04:53 PM
MEATMASTER's Avatar
Cobra Make, Engine: Johnsonville, 8-pack $4.27
Default Ultra-Shift!
Ultra-Shift!
Cobra Valley's Chemicals - Ultra-Shift Transmission Lubricant
Some amazing stuff over the standard GM oil.
MM
Smoke the meat, only the meat and nothing but the meat... so help me Weber
Old 11-20-2011, 06:06 PM
Dwight's Avatar
Smile
I have used Ultra-Shift in two of my Tremecs. It did what they advertized. I love and will you it again.
Read all the info on it, to much is BAD.
Dwight
