Old 11-27-2013, 05:23 AM
ha_pe_1968 ha_pe_1968 is offline
Cobra Make, Engine: SPF 2234 Diamond Edition, Roush 427R
Originally Posted by madmaxx View Post
As I am become a SPF addict and now on my third I have found a common issue. The supplied motor mounts are not up to the task. They allow the engine to rotate under torque which allows the side pipe to smash into the bottom of the opening on the passenger side. This deforms and cracks the area. Either get the energy absorb mounts, go solid or use a chain to prevent the engine from rolling over. Chain looks tacky IMO but better. Than damage.
Hi!
Try the Olthoff Polyurethane mounts...problem should be solved then. Even with that mounts it can be tight at the passenger side - but no contact to the fiberglass.
Peter
