Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 10-04-2010, 02:18 AM
Default Car Performance secrets?
Over the past few years i have become obsessed with my cars performance. I would like to know if anyone knows any secrets to tuning your cars. my current car(just got it 2 days ago) is a subaru forester with a 2.5L EJ251 flat 4 engine, a 4 speed automatic transmission and 114,000 miles on the engine. Because of the high mileage i will not add a forced induction system. Because i don't want to run high octane gas i don't want to increase the compression.
I will list some of the performance stuff i already know(so you don't waste your time). Increasing volumetric efficency: this includes better filter, intake, heads, valves, headers, high-flow cat, and straight-pipe muffler, and building resonance(provides small boost in NA engines).; getting getter fuel air mix through new injectors; Better timing whether it be through new camshafts or ecu injection timing. raising redline through stronger parts + shorter stroke; increase displacement physically or virtually(i would also like to shy away from this).
Old 10-04-2010, 04:44 AM
Tom Wells's Avatar
The answer to your question is very simple MR/MS wilkinse,
Since you posted this in the 460 forum of a Cobra web site, put a 460 in your Cobra!
Tom
Old 10-04-2010, 08:02 AM
FWB's Avatar
FWB FWB is offline
performance secret to a subaru is to crush it,.....then build a cobra that has ten times the horsepower.
Fred B
Old 10-04-2010, 08:10 AM
Silverback51's Avatar
And I thought I drank to much.
John Hall
Old 10-04-2010, 08:31 AM
Cobra Make, Engine: None. Yet.
My 2005 Saab 9-2X Aero (which is mechanically identical to a Subaru WRX) will do 0-60 in just over 4 seconds. It also has room to spare for 4 adults and a week's worth of luggage.
Originally Posted by wilkinse View Post
... my current car(just got it 2 days ago) is a subaru forester with a 2.5L EJ251 flat 4 engine...
I will list some of the performance stuff i already know...
That's all a waste of time with a naturally aspirated Subaru engine. About the best you can do with the EJ251 is cams and an ECU tune which, if you're lucky, will get you to about 130hp at the wheels.
You can swap in the WRX or STi engine with relatively little effort and put larger turbo on it. At that point, the sky is the limit: 500hp is pretty easy, and 800hp or more is doable with meth injection on an upgraded block.
Member since 1999 - and I still don't have a Cobra!
Old 10-04-2010, 09:01 AM
Zoom This's Avatar
Maybe a Subaru forum can give you more secrets than a Ford based forum. Like Tom said, stuff a 460 in it........ or get some tuning secrets from a Subaru racing forum.
Rate This Thread:
