| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
09-08-2011, 08:47 PM
AZ
thats the good thing about it if its not an original cobra who cares
PRIDEnJOY
09-08-2011, 10:27 PM
AZ
Cobra Make, Engine: Alum bodied CSX4266, fuel injected alloy 472, 663 hp Engine built by Dralle. Suspension by Tom Barnard
I have experienced the following after going to fuel injection: The efficiency of fuel injection made my cars exhaust a bit quieter, the roughness or lumpiness at idle was far reduced, I'm sure the fuel mileage had to improve, the car is much more drivable and responsive and it just looks too cool!
Don't underestimate the predictability of stupid!
09-08-2011, 10:54 PM
AZ
Cobra Make, Engine: Factory Five Roadster
Slither...I have a FFR, 302 w/TWM and would like to meet you sometime at your convience. I live in Avondale. Give me an email at bbryan00@cox.net or call 935-0865. Thx
Bill Bryan
09-08-2011, 11:17 PM
AZ
Air Filters for TWM
Originally Posted by Crazylunker
I'm actually not having any problems with the tune, I'm kind of old school and like the simplicity of the carb and distributor, What is putting me over the edge is finding an air filter/screens I like that doesn't cost an arm and a leg. I'm running an electromotive tec3 distributorless, I like the period correct look of having the distributor and wires as well.
Try to contact Bill Hirsch in Warren, Michigan @ Bills B Racing. Email is Stackcovers@aol.com, Tele: 586-883-0942. He's a great guy and offers a good filtered product that reduces HP at intake the least of all filters I believe. He can explain it better than me. I noticed a difference in my TWM immediately.
Regards,
Bill Bryan
04-04-2012, 12:43 PM
BC
Cobra Make, Engine: CAV GT40, Ford Racing aluminum 427 Windsor
Quote from twobjshelbys
"One thing the fuel injection does though is put a pretty hard limit on the top RPM. Mine is 6500, but the engine ought to be capable of doing something like 8000 with a good carb setup. My engine is a Roush 427IR Windsor based."
Why do you say that the fuel injection puts a pretty hard limit on the top RPM at 6500? I am planning to put the 8 Stack Injection (Classic) units on a 427 Windsor solid roller cam engine that I expect will easily rev to the 7500 rpm + range. Does anyone have comments on this?
Thanks,
Gord
04-04-2012, 02:28 PM
AZ
Thanks,
Gord
I have NEVER been limited to RPM's in the 8 years I have been running the TWM stack injection and the Redline ECU! Why would the injection system put a limit on RPM? Wouldn't that fall under the ECU's performance? My engine is a Dave Dralle built all aluminum big block FE. Could there be a difference there maybe?
04-05-2012, 11:13 AM
BC
Slither
I agree that there should not be any limitation of RPM by the 8 stack injection itself. That is governed by the type of lifters, valvetrain and ECU. With a solid roller cam, good valve train andfuel system and the correct ECU programmingThe power level at high RPM and is then dependent on the cyl heads, intake and throttle body flow rates. RPM achieved is governed by the mechanical components.
I suspect that the 6500RPM that twobjshelbys refers to is mainly governed by the ECU and hydraulic roller lifter valvetrain.
Gord
04-05-2012, 11:32 AM
AZ
Slither
Gord
Makes sense to me. I agree with you!
04-05-2012, 12:27 PM
OR
Originally Posted by zrayr
uhhhhh, the OP's already stated that he likes the look & feel of original type equipment. Nothing wrong with that. That's the basic reason we ALL like Cobras.
Z.
I couldn't agree more. Nothing wrong with a polished arruminum cobra with stack injection, if that's what gets ya goin'. Some of us just like it old school.
ERA FIA 2088
04-05-2012, 01:05 PM
Tx
Cobra Make, Engine: CSX6128 with Shelby 468FE
Agreed, I just love the look!
Andig
04-05-2012, 05:57 PM
Backdraft Racing Dealer
CT
Andig
New tune today... Seems to be running mucho goodo.
04-07-2012, 04:47 AM
Me
I too toyed with the idea of how to leak fuel into my build but then it was either Webers or a single carb.Ran an 850 dbl pmp for a few years never liked the rich idle loved everything else.Then discovered Dan Davinci he built me a 1000cfm dbl pmp all I can say is Wow, both me and the 460 could not be more satisfied and the idle is just what I had hoped for lean and nasty! EFI of any kind was never considered partly because of the expense and complicated nature of the beast,not to mention no narly idle with electronics.Finally for me wanted the old school look when hood was lifted,it speaks volumes to we old schoolers.
04-24-2012, 10:31 AM
BC
Cobra Make, Engine: CAN-AM cobra, 460 SVO
I love everything about the stack setup... except the COST... cant justify it yet. Clsoe to $10,000 recently quoted for a full Eight Stack system including computer and fule pump etc.
8 Stack Fuel Injection/FAST XFI Computer
429-460 cu inch Ford with 2" velocity stacks included $7595.00
Aeromotive Fuel Pump, regulator and fuel lines - AN/Steel braided high pressure : $1199.00
Polished Intake Manifold: add $599.00
Polished Throttle Bodies and Stacks : add $1099.00
100 Micron Screen Stack Covers: add $399.00
Maybe when it fails aircare emissions testing next week I can justify it
Mark
04-24-2012, 10:42 AM
Member of the north
Cobra Make, Engine: A Cobra
My weber works great.
I can cook burgers, dogs, brats and chicken all at the samne time. That charcoal taste meake the cookout.
That is my weber.
04-24-2012, 01:23 PM
Cobra Make, Engine: #6101 streetbeast Ingelese stack EFI 351w/t-5 9" 4link 3.55
Andig
That is just beautiful!! Carb....aaahhh no thanks!!
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
