9Likes
07-31-2011, 08:19 AM
Shifting a monster to the drivers side?
 Thanks Tim. You have any interest in having a phone conversation to educate me a bit on these big blocks. I am helping out an old friend with this car he is attempting to build.
Carl in Riverview
813-643-9111 or I could call you?
08-01-2011, 10:57 AM
Looking for more information
Any reason why it would go on the passenger side and not the drivers? Educate me please!
08-06-2011, 04:09 PM
Me
Our CMC car was built 93/94,frame was set up for tubular uppers and lowers front and back with clearance for belly exhaust, 2600 lbs.
460 .030 over forged pistons
new beam rods arp 2000 bolts
balanced and blueprinted
Aluminum heads ported and polished
Lunati flat tappet .235 @.050, .560/.560
Edelbrock RPM
Dan Davinci 1000 cfm dbl pmp Holley
Mallory Unilite
aluminum water pump
Tubular Automotive custom racing headers
Stainless Specialties mufflers
Aluminum flywheel
Clutch pressure plate balanced with flywheel
Tremec TKO 5 speed
Strange aluminum center section 9" with 3:73 gear 31 spline moser axle,Traction-Loc
posi set up tight
Coilovers all around and car has been scaled
12" Wilwoods dual masters with balance beam
Have road raced the car and a little street/drag race when the need arises.
This car could be driven year round with top and windows in but do not.
Car just sitting still pushes the right buttons as you all know.The very first magazine article I read about the 427 Cobra back in the 60's have lusted over these beasts ever since.
08-29-2011, 03:20 PM
IA
Cobra Make, Engine: Shell Valley
I am running a 429 originally from a 71 T-Bird. The engine was rebuilt with high compression TRW pistons, Edelbrock dual plane intake, mild cam for rpm range of 1500-5000 rpm. I don't have any dyno or hp info on the setup. It has great low end and midrange, great for street cruising. Would love to try a set of the late aluminum SVO heads, intake and SVO cam for the 460 for more top end power.
Jay
08-31-2011, 12:44 PM
Cobra Make, Engine: Superformance, 460 SVO
SPF 0923 460. Highland Village, TX
Shawn Keith, SPF0923
12-08-2011, 01:57 PM
AL
Cobra Make, Engine: Midstates, 545 stroker
I gotta Midstates Cobra with a 545 and a toploader transmission.
12-25-2011, 01:40 PM
BC
Cobra Make, Engine: Classic 66cobra/429ci
stock 429 in a 66' Classic Roadster
12-27-2011, 04:55 AM
Me
When I was contemplating ci for my car had no clue how much would be too much.Wish now had trusted my gut and gone with 500+cubes.The 460 I built has all the go fast goodies was blueprinted and is a sweet motor but still wonder what say having the cubes like your 545 would be like.
Was the 545 built for topend power or off idle grunt? What is it like driving around,and have a lot more questions.
Have been thinking about pulling aluminum topend off the 460 and setting up for big solid roller cam getting into the 650 hp range. Mike Ross
08-23-2012, 01:24 AM
Cobra Make, Engine: FFR with 460
Have the 460 as well, pulls like a 16 yo school girl..
08-28-2012, 08:41 PM
Ont
Cobra Make, Engine: Boss Replica Motors BB 460 by New Generation Engines
I have a 1970 460 that has been modified by New Generation Engines of Fonthill Ontario Canada. The unit produces 740 HP/ 680 foot pounds of TQ at 6000 rpm. Lots of grunt as the torque starts to kick in at 1400 and pulls strong to 4500. Then the RPM takes over to 6000. The carb is a Holley 4150 HP Double pumper (No choke) flowing at 740 cfm. It works great! That is if ya don't run out of road.
09-23-2012, 11:49 AM
ON
Cobra Make, Engine: 605 C.I. Pump Gas
Running a 460 Eliminator Ultra Block 605C.I. on pump gas, 798 solid lift cam, SCJ Blue Thunder Aluminm Heads, SV1 Pro Systems Carb 1120cfm
09-27-2012, 03:31 PM
sc
Cobra Make, Engine: b&b
hi,i am buisey building a cobra with a 460 and a c6,i am wanting to put coil overs,the guys want to know what weight is on the front wheels,so i can get the correct springs,also any information on the cooling,radiator,fan etc,thanks
10-11-2012, 09:27 AM
Cobra Make, Engine: SPF 239
Here is some 385 series eye candy...
12-27-2012, 10:52 AM
co
Cobra Make, Engine: superformance 514ci
Hi Guys - My Superformance #508 has a 520ci (stroked 460) - wicked ride - most fun on 4 wheels i have ever had!!
D.Kelly
Thornton, Colorado
12-27-2012, 05:08 PM
12-28-2012, 05:29 AM
Cobra Make, Engine: A&CAuto 460
Upgrade
Changing From 460 To 521,First Gen.Kasse SCJS. Redoing AOD With Lentech Valve Body,Should Be A Fun Summer.
01-12-2013, 09:31 AM
Cobra Make, Engine: Ford & Carrol Shelby
429 SCJ-RA-Drag Pak
Hello All : Dan here, been a member for quite some time running a 71 Mach 1
429CJ-RA 4-speed in original Grabber Blue. Documented 1 of 2 known left to
exist according to the 429 Mach 1 Registry with factory A/C.
Recently added a new member to the family in the form of a Candy Red 70
Cobra. Numbers matching front to rear "barn find" with the real deal 429SCJ
w/ram air - 4 speed - Drag Package. Yup the original "W" code 4.30 locker is still in place.
I'm 50% done on a concour rotisserie OE restoration - but times being what they are I'm considering letting it go. Wishing everyone a fine day & hope to visit again soon.
Dan Wasvary
06-28-2013, 01:55 PM
Cobra Make, Engine: ANTIQUE AND COLLECTABLEFORD 460
I'm Sporting the best engine ever made...... THE 460 of Course!
04-26-2014, 07:54 PM
A 460 in a F5.... runs great.
04-27-2014, 04:27 AM
Me
Our 460 powered car has been keeping us happy for 21 yrs. now. Over the years have tweaked the suspension to road race, stepped up the performance to near 530hp. Except for a racing seat and stickier rubber the car is a pure thrill ride. The best hot rod we have ever owned bar none.
