9Likes
04-07-2004, 01:53 PM
1969cobrajet, it depends
429/460 blocks have the same bore. what you end up with depends on the crank/pistons.
429/460/514/533 etc. could all be the same block.
04-13-2004, 10:38 AM
md
Cobra Make, Engine: 03 SHELL VALLEY 500CI
460 TAPPED TO .060 OVER AND 550 HP...RUNS STRONG.....BD
05-15-2004, 08:19 PM
MS
Cobra Make, Engine: FFR---460
Hey guys, I'm picking up my Factory five Roadster June 1st. I've ordered it for a big block. I've got the short block built. 30 over flat tops, hoping for 10.5:1 comp, cobrajet rods. Now I saving to buy the Edlebrock RPM setup: 75cc heads, cam kit and intake. Looking for 475+HP. Options also ordered with FFR: full IFS & IRS
pindrive setup, Trigo knockoff wheels, leather. Can't wait!!!
There's no substitute for CUBIC INCHES! Greg Kemp
05-15-2004, 11:27 PM
Registered User
MN
Cobra Make, Engine: 67 Shell Valley - Kevlar; 514:TKO
Reaction re reduced port size from Ford Motor Sports...
The guys at Ford Motorsports Technical are great.......cept sometimes I feel like you get too much "personal opinion" thrown in on some questions.....
Spoke with one of their guys with some clutch questions........he went into a short disertation on optimizing the 514 Cobra Jet heads by reducing intake and exhaust ports.
This obviously is counterintuitive - he suggested specialized process was adding 100 HP and Lbs at lower to midrange.........(Like we need it).......I've been working on trying to get more air to mine to make sure it's breathing properly at higher RPM........
Curious if anyone else has heard reference to this new approach. Supposedly increases velocity and angle of air into combustion chamber ya da ya da......
FYI mostly.
05-19-2004, 03:29 PM
NJ
Cobra Make, Engine: Everett-Morrison 514ci, 5sp Tremec
I've got a 514..love it!
Josh
jjtarnow
07-18-2004, 07:18 AM
NJ
Cobra Make, Engine: (building) - Hunter #74 w/ 302 small block (320hp under the hood). . . how many wires are there in a wiring harness?
Just checking in here . . . . .
Have a nice 460 sitting in my garage waiting to be put in my Hunter #74.
I'll tell you, a 460 sitting in the middle of an empty garage makes for a very nice conversation piece. Actually had someone driving by my house, stop and ask me what it was!
I'm not busy because I did it right the third time . . .I think!
07-20-2004, 10:53 PM
Cobra Make, Engine: FFR Mk 3 408 530 - 585 T- mustang Dyno at B&R
My FFRMark III with 460 will be finished in Sept; Brake HP @ 613; brk Tq. 556; compression ratio of 9.5; Bore 4.362; Stroke 3.85; Holly 1000 CFM HP Carb; Custom 4 into 1 with Chevy flange. Can't wait.
07-27-2004, 02:33 PM
Cobra Make, Engine: ffr mkiii 514ci tko600 irs
514CI FFR MKIII
FFR MKIII 514CI TKO600 IRS
08-09-2004, 03:03 PM
il
Cobra Make, Engine: spf 1837 408w 93mm turbo
429 now 577
i have just finished installing a 429 that was built from the ground up as follows:
bored and stroked to 577 cu in
c460 aluminum heads and matching frrp aluminum intake manifold cnc ported and polished. flow reading at 450 cfm. intake valves 2.400 exh. 1.900
je pistons at 10.75 to 1
holley 1250 dominator
comp cams 700 lift 112 duration
crower rods
ferrara st st valves
stefs low profile oil pan 9 quarts
danny bee gear drive
msd 7 ign with blaster coil
jesel roller rockers with solid lifters
billet valve covers
johnston vacuum pump
mcleod bell housing
tko II
BAD ASP
spf 1837 408w intercooled turbo t56 viper 6spd
95 mustang cobra 408w vortech t trim supercharger
71 torino cobra 429 scj
66 ford galaxie 7 liter
68 buick wildcat 430
08-22-2004, 08:34 PM
Mike,
Wow, it sounds like you maxed out on every thing on this engine. How much are you expecting - you could be pushing 700 hp. with that combo.
6th generation Texan....
08-22-2004, 09:49 PM
CO
Cobra Make, Engine: 1989 West Cost Cobra 1969 429ci - Edelbrock RPM Cam with roller rockers and Torker II Manifold - Heads ported/polished with Manly 2.25" intakes - Bottom end blueprinted/balanced with TRW pistons - Holley 800DP - MSD Ignition - Dyno tested 510 HP
New owner - 429ci, 510hp, Lots of torque, Lots of cool sounds coming from side pipes, Lots of fun sitting at red lights, Just lots of fun. Hal
08-24-2004, 10:27 AM
il
jdean
you're right and wrong. the suggested horsepower is short of the actual engine dyno numbers. i am having a chassis dyno done next week so i'll let you know then, we're expecting a little over 825 and 790 torque. fingers crossed
BAD ASP
08-30-2004, 02:33 PM
in
Cobra Make, Engine: 1972 429
hello, to start im not sure if im in the 385 family. i dont know to much "i know ive been smoking chevy's" about ford motors. i own a 1972 429 that i had built "cost around $4,000" and im not happy with the builder. he wouldn't give me any information on what he did with the motor. i need help, i bought the motor at a junk yard for a $100.00. my qeustion since i cant afford a true cobra, can anybody help me with a plan specs a parts list so i can rebuild my 429 as a cobra. if so post here or email me at k9_zeke@yahoo.com
11-10-2004, 06:03 AM
Me
460 sign in
I have been running a 550+hp 460 for almost 10 yrs. This last couple of years have been especially exciting.I changed the toploader and 3:54 gear to a Tremec TKO and 3:73 gear.The excitement factor is off the scale.Every time I fire up the beast,a transformation takes place,and it is impossible to describe.You Cobra guys understand.I truly enjoy passing cars with the hammer down.Life is good!!
11-10-2004, 11:46 AM
NM
Cobra Make, Engine: West Coast Cobra weber fuel injected 557 C.I.. 800H.P 760LBS. TQ. Magnum T56
FOR SALE$$$$$$$$$$$$$$$$
WHEN YOU HAVE MORE HORSEPOWER THAN YOU NEED ITS STILL NOT ENOUGH!!!!!!!
12-04-2004, 09:24 PM
NJ
Cobra Make, Engine: Shelby CSX 4305 40th Anniversary #26 of 40 Limited Production Factory installed Stage 3 Supercharged 460 Stroker 858 HP
I'm in, supercharged 460 stroker.
Supersnake
12-28-2004, 05:39 PM
OH
Cobra Make, Engine: Superformance 460
I have 4 month old SPF w/ 500hp 460 hooked to Tremec & 3.73 rear. The only minor concern has been that 1st gear is a little low & we are grabbing for 2nd awful quick. Getting 7 mpg in town and 11 to 12 mpg on the road @ 65. Love it!
12-30-2004, 01:18 PM
Cobra Make, Engine: don't have one
460 with a Crower Solid Roller cam & Rockers. Eagle steel crank.
ported & poished 429 D0VE-C heads Weiand Dual Plane intake
(Stealth); Keith Black Pistons; BOSS 429 Steel rods, Holley 4150
dbl pumper w/mechanical secondaries, progressive linkage,
4-corner idle jets, and annular boosters.
I have a '67 mustang coupe unibody shell that I'm collecting Shelby GT500 body parts for. PLan on creating a "resto-mod" clone of a Shelby GT500 ...No it's not a real snake , but it'll do.  )
01-02-2005, 06:44 PM
NC
Cobra Make, Engine: Midstates. Ford stroked 460 (to 514) blue/white
Never thought I would say there was such a thing as too much HP. I stroked mine to 514 and put roller everything in it. I am shaking it down - tuning the 1050 dominator is a challenge - but learning! It is in a Midstates Cobra. Bob K. is great to work with!
01-16-2005, 08:50 AM
Cobra Make, Engine: Shell Valley, Ford 429, top loader
385 engines
I have a 1970 SCJ 429/500 hp in a Shell Valley kit and a 1969 stock 429. I am thinking of selling the SCJ and going with the milder 429.
