Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Like Tree20Likes
  #61 (permalink)
Old 08-16-2017, 01:10 PM
cycleguy55's Avatar
Originally Posted by Texasdoc View Post
Just an honest question... Not trying to pick a fight.
You need better airflow to cool your radiator. But you refuse to replace the mechanical fan that is the root of the problem. Why keep complaining about too much heat if you won't fix the main problem?
It's cool if you want the look and are willing to trade the "look" vs "running too hot" but you can't have both. Your call.
I'm reminded of my grandmother's many trips to various doctors, seeking the cause of her ailments and the magic potion that would cure her ills.
She never could accept the fact she was in her mid-'90s - and her problems were simply that she was getting older. She finally passed away a few months after turning 100.
Brian
  #62 (permalink)
Old 08-16-2017, 04:31 PM
FWB's Avatar
FWB FWB is offline
Originally Posted by ByronRACE View Post
https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
Ran across this today in my amazon saved items list...thought it might be helpful.
Careful, the Dorman may look almost the same but its performance is far below the factory lincoln unit.
the blades are a different shape and there is one less blade.
i put a lincoln fan in another kellison with a 429 SCJ, which always ran hot previously, i used a flexolite programmable controller to set the on and off temps, and it worked flawlessly, had to make two clearance cuts in the shroud for hood hinge clearance and block off the opening between the rad and the inside of the body.
Fred B
  #63 (permalink)
Old 08-16-2017, 08:26 PM
Cobra Make, Engine: A&C (near future)-460
Default ok - I give
It's obvious the electric fan (Mark VIII) seems to be the best option...or one similar in CFM.
However, "The reason that I am running a mechanical fan is to move more air through the engine compartment to try to relieve the inherent heat of a Cobra"........ So many of the articles over the years talk about heat trapped in the engine compartment.....I'm not worry about HP...it'll be fine!
SO, I'll need some type of electrical fan (Mark VIII) to help out the Mechanical Fan...to keep it cool....
Maybe I'll get one shortly just to satisfy myself....before I mount the body..
(cycleguy55 - Sorry about Grandma!)
Thanks all, some very good info and thanks to ByronRACE and cycleguy55 for references for parts!
PJ
cycleguy55 likes this.
  #64 (permalink)
Old 08-17-2017, 12:04 PM
Texasdoc's Avatar
Maybe since the electric fan moves a ton more air thru the radiator, it will move air thru the engine compartment too, solving both problems.
  #65 (permalink)
Old 08-17-2017, 12:24 PM
cycleguy55's Avatar
PJ
Based upon what I see in your video ( https://www.youtube.com/watch?v=JTcaeBe7fAg ) it appears you have lots of room to install an electric puller. You could pull the shroud, install the fan, and re-install the shroud. You'd have the cooling you need for crawling in traffic and the mechanical fan to keep air moving through the engine compartment at all times.
Good luck.
Speedwaypj likes this.
Brian
  #66 (permalink)
Old 08-17-2017, 04:28 PM
Gaz64's Avatar
Correct.
  #67 (permalink)
Old 08-17-2017, 05:35 PM
ByronRACE's Avatar
Cobra Make, Engine: West Coast Cobra w/ Centrifugally Blown Big Block, Pickles, Onions, on a Sesame Seed Bun.
Default Cooling power vs vehicle speed.
I think you'll find that you need LESS fan when the vehicle is in motion; which is one major benefit of an electric fan. You're not burning power moving all that air needlessly. Better for gas mileage; which we all know if high on our priority list. My point is, a garage fan is nothing compared to the vehicle going down the road at 30+mph. In my case, the fan turns off and stays off at freeway speeds; even when climbing a grade. If you slow down below 30mph, it comes on. When you get off the freeway and pull up to the first stop sign, it turns on.
Gaz64 likes this.
  #68 (permalink)
Old 08-17-2017, 05:51 PM
ByronRACE's Avatar
I just saw the video above. In my opinion, the engine fan is too far away from the radiator to make a shroud practical. As it sits now, it's doing nothing. Even if you did build a big elaborate shroud, you don't want all those shroud walls boxing off valuable space in the engine compartment making it hard to work on. I would put the big electric puller on it and enjoy the freedom of being able to service the front of the engine. There are no reliability problems with OEM electric fan designs these days. My daily driver has 230K miles on it, the climate control is always on auto, and the fan is always on. No issues.
Additionally, that garage fan is not a pressure blower. Most likely, very little air is actually going through the radiator; it's going around it or just swirling inside the fan housing.
Try the lincoln fan. If you're not amazed, return it. One advantage to amazon.
  #69 (permalink)
Old 08-17-2017, 06:42 PM
Texasdoc's Avatar
I agree with the above. The video shows the mechanical fan is way too far away. The garage pusher is likely not doing much either.
Oh, and by the way, it sounds FANTASTIC.
  #70 (permalink)
Old 08-18-2017, 07:34 AM
Thx for the input all. The video was prior to my fabricating a shroud. Yes it does take up a lot of space. It (mechanical fan only) holds pretty good (under 210F) for about 25 minutes...then I need that garage fan to keep it from getting too high. Underway it should be ok.
I don't think putting a puller fan (i.e. VIII) AND keeping the mechanical fan with shroud would work correctly...I would think the electric fan (while not running) would itself create a restriction, whereas the mechanical could not pull enough and result in kicking on the electric fan...
Again, thanks all for the input!
  #71 (permalink)
Old 08-18-2017, 10:09 AM
ByronRACE's Avatar
Default Restriction.
Even with the twin pushers on mine, turned off, moving down the road is enough airflow. That's with no shrouding in front of the radiator; just the body opening and air is free to bypass the radiator and flow all around it. It's still enough.
I can't imagine the single puller being more restrictive. If you like the shroud and mechanical puller, that should be plenty...especially if there's no fan clutch. It should be overkill if the shroud is designed right with no leak paths and the fan positioned at the right depth at the outlet so the fan is efficient. Even at idle when you're not moving, that should be plenty. If you have any leak paths where the fan is moving air that did not first flow through the radiator, the air will favor that path...especially at idle. Even a small 1/2" gap all the way around where the shroud meets the radiator will make a significant difference. The total area of a gap that large provides a less restrictive path than the radiator. If you look at OEM radiator and shroud designs, there's all sorts of seals and bits of plastic placed here and there to channel the air through the radiator instead of around it and to prevent hot-side air from recirculating around to the cold side and being sucked through the radiator again when the vehicle is stationary at idle.
My dad split the fan shroud on his E150 to make it easier to work on. The result of this created a 3/8" gap in the middle of the shroud on both sides, and about a 1/4" gap between the radiator and the shroud on the top half of the shroud. At idle, it would overheat. I duct taped up the fan shroud to experiment and it solved the problem. Ended up having to buy a new OEM shroud. The small stuff matters.
Gaz64 likes this.
  #72 (permalink)
Old 08-19-2017, 12:11 PM
cycleguy55's Avatar
I have dual 12" fans on mine, thermostatically controlled (adjustable controller with prove in radiator fins) with an override switch on the dash. I have recently started turning the fans on about 1/4 to 1/2 mile before reaching my destination and, when I do, then fans rarely cut in after shutting off the engine. Before I started doing that I found the fans would run quite a long time after shutting the engine off. Obviously what I'm doing is cooling off the radiator enough to keep them from running, but I'm betting there's also a significant drop in under-hood temperatures as well.
Brian
  #73 (permalink)
Old 08-24-2017, 09:49 AM
Expansion/surge tank (and overflow tank);
I integrated a 2qt expansion/surge tank (and 1 qt overflow tank);
Initial timing @ 13 BTDC ; Total @ 33 BTDC (w/o vac)
80 F ; Ran Aux garage fan.
Much better; after 45 minutes of running (@idle) radiator pressure only went to 6psi and temp stayed under 210F.
So I'll plan an electrical Puller with high CFM...and the mechanical Fan
Time to move past this now.
Again, thanks all!
PJ
  #74 (permalink)
Old 08-25-2017, 09:31 PM
FWB's Avatar
FWB FWB is offline
hold the phone........6 PSI?
what LB radiator cap do you have?
Fred B
  #75 (permalink)
Old 08-27-2017, 01:15 PM
Default Radiator cap
I have a 21# right now because it was getting to 18psi (w/o expansion tank) and the 16# and 18# wouldn't hold. Now with the 2qt expansion tank there is more (air) volume so it's not nearly as high now.
  #76 (permalink)
Old 08-27-2017, 05:51 PM
Gaz64's Avatar
Why don't you fill the whole system up full via the expansion tank?
Expansion tank is really the wrong word, it is a header tank, if you have an overflow bottle as well.
  #77 (permalink)
Old 08-28-2017, 09:18 AM
cycleguy55's Avatar
Update:
- I R&R intake gasket with Fel-Pro which block the exhaust cross-over.
- I used the "Cooling System Vacuum Purge And Refill Kit" to try to eliminate any air pockets.....it actually worked pretty well.
- I did add the bleed lines to the intake. I drilled a hole in each intake side matching the (blocked) head water ports. Tapped (1/8 NPT) for small hose fittings and connected them with a "T" and then ran it to the gooseneck.
As I mentioned previously the radiator is new; but I have taken it off again and back flushed.....seems to flow fine.
- Results. ( 80+F) ...not much difference.....(I have an in-line radiator cap - no surge tank yet - on order)....I used a "Spill-free-funnel" to be able to monitor it.
- It pushed out about a pint+ or so....it started from about 5 minutes on.
- Also notices very tiny bubbles occasionally....from 15 minutes and even some at 45 minutes.
- I also ran a Strong garage fan on the radiator the whole time....at 40 minutes it was at 195,....when I turned the Fan off for 3 minutes, it went to 210; turned fan back on and it went down to 205.
- When I revved the engine for a minute it would drop a few degrees.
My goal is to keep the mechanical fan, build a better shroud and add two front fans (ERA type). (yes I'm sure the Mark VIII fans would work best).
Next - integrate the expansion/surge tank (and overflow tank);
- Maybe get an undersize water pump pulley.
Again, thanks all!
PJ
Perhaps I missed it, but I haven't seen any posts about the normal expansion / contraction of coolant in the system. Coolant expands at about 7% per 100°C / 212°F of temperature rise. That's why coolant recovery bottles have separate marks for Cold and Hot.
If your engine is 'cold' at 70°F, then going to 210°F, that's a rise of 140°F, and the coolant will expand about 4.6% (140 ÷ 212 x 7% = 4.6%). Assuming a total coolant volume of 15 quarts, the amount of expansion will be 0.69 quarts, or about 22 ounces or 1.38 pints (15 x 4.6% = 0.69).
It would appear the "pint + or so" amount of coolant being pushed out is quite typical - certainly well within the range of 'normal'.
BTW, running a 21# cap is okay if your system is designed and built for that level of pressure. Many cooling systems, OTOH, were designed for 15 PSI or lower and won't handle that pressure reliably. You have a new radiator, so may not have any issues running that kind of cap, but I would be cautious about using a higher pressure cap than the system is designed for.
Brian
  #78 (permalink)
Old 08-30-2017, 05:45 PM
thx for the info - cycleguy55
I was only using the 21# because it was getting to 18psi (w/o expansion tank) and the 16# and 18# wouldn't hold...it would push out coolant thus causing overheating. Now with the 2qt expansion tank there is more (air) volume so the pressure is not high now. I plan to go back the 16# and adjust coolant level.
