Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 04-11-2005, 04:11 PM
Default 460 turbo? supercharged?
Thank you for helping me with the past forum. I have decided to get a 460 big block and make it just for a blower, now I have one question....
?Turbo or Supercharger?
Old 04-11-2005, 05:07 PM
Cobra Make, Engine: West Coast Cobra weber fuel injected 557 C.I.. 800H.P 760LBS. TQ. Magnum T56
Send a message via AIM to MAXVELO
Default supercharger??
if you decide to go with a Scharger, I have one that I am planning on selling. I custom fabricated all the brackets intake etc. I also have a killer fuel injection setup includingt a blower cam & lifters. Check out my gallery for pics. I blew this motor last fall and am parting ot out. all the damage was in the number 1 cylinder (sucked a valve) motor had less than 400 miles on it when this happened! Let me know if you can use any parts! if not, disregard this post!
thanks Gary cell(505) 250-8565 eves (505) 242-4567
WHEN YOU HAVE MORE HORSEPOWER THAN YOU NEED ITS STILL NOT ENOUGH!!!!!!!
Old 04-13-2005, 09:16 PM
ByronRACE's Avatar
Cobra Make, Engine: West Coast Cobra w/ Centrifugally Blown Big Block, Pickles, Onions, on a Sesame Seed Bun.
Default Detonation resistance is key.
If you're running pump gas, the #1 consideration is to build the engine as detonation resistant as possible.
How?
Aluminum heads. Low compression. Ceramic coated pistons and chambers. The right cam. Reasonable boost levels, tuning, and constant monitoring!
And, it goes without saying that the components chosen need to be appropriate for the power and rpm you are going to generate. Quality rods, crank, pistons are a must.
My combo can be seen here: http://www.racesystems.com/cobra
It's a 433" BBF with a custom V7-JT Vortech setup, fuel injected. 7.88:1 compression, 14psi, 91 octane. I'm using CP pistons, billet crower rods, a forged 429 heavy truck crank, 4-bolt billet mains, aluminum blue thunder heads that flow 410/310, solid roller valvetrain.
I should have it running this spring...I'll post dyno data.
Old 04-14-2005, 06:09 AM
ByronRace, your WEB address is no good.....
Old 04-14-2005, 09:58 AM
ByronRACE's Avatar
What part of it do you think is bad? I just clicked it; works fine.
Old 04-14-2005, 02:07 PM
ByronRace, Thats wierd! It worked fine this time. Very impressive!
