Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Like Tree1Likes
  #21 (permalink)
Old 07-11-2006, 06:02 PM
Club Cobra Member
Cobra Make, Engine: Superformance 460/514 stroker
Default Got 514 problems
514's need lots of air....and clean air. I have two twist in oil breathers and a PVC that is NOT from a hot rod shop....those are NOT sufficient for the crankcase to breathe. Any questions send me an e-mail rwm29@comcast.net
I've had mine for 5 years and no troubles.....626hp and still going strong.
bob514
  #22 (permalink)
Old 07-12-2006, 10:43 AM
ByronRACE's Avatar
Cobra Make, Engine: West Coast Cobra w/ Centrifugally Blown Big Block, Pickles, Onions, on a Sesame Seed Bun.
Default PCV + Breathers
So if you're running a PCV with an open crankcase, how did you tune around the vacuum leak?
With a PCV, the air path would the through the breathers, through the crankcase, through the PCV, and into the carb...which is a vacuum leak. That air would not flow past the carb venturis and fuel wouldn't be metered for it...which should cause a lean condition most noticable at idle and light throttle.
Did you just richen idle fuel to compensate? Any weird off-idle stumble problems?
  #23 (permalink)
Old 07-12-2006, 11:36 AM
Back in Black's Avatar
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Here's the latest:
Finally found a shop that could do the job right.. there's nothing wrong with my engine!
I had initially taken it to Blood Enterprises in Auburn, WA but the result was:
1) Mr Blood could not get it tuned.. suspect he does not really know much about this issue and just wanted to rid himself of the dilemna
2) My windshield chrome trim has two nice scratches in it
3) Someone at Blood used my chrome front hoop bumper to pull on to move the car (a BIG no-no) and pulled the support tube out of the socket receiver. Fixing that today
4) Because he told me the engine was "hurt" I paid $240 to truck it to my buddy's shop where we discovered the problem was operator error at Blood
5) Paid Mr Blood way too much for very little result!
I finally took it to a really great local shop: Horsepower Connection in Olympia/Thurston County.
http://www.horsepowerconnection.com/
Brian is a great guy and very competent. He got it going with a complete reprogramming, reattaching the PCV valve and some adjustments and 3 hours on the dyno. Far less cost than Blood, to boot.
Must replace my hokey stock throttle cable bracket so I'll be going back there for a little final work when the part comes in, but I drove her home last night and she's running great with the EFI.. finally!!!
Trubble likes this.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
  #24 (permalink)
Old 07-12-2006, 11:50 AM
PS: Advice on an extra intake breather noted and if I have problems I will do this but during the full on dyno pulls there was zero oil emitted with the PCV properly attached. I suspect as the engine breaks in a gets a few K miles any potential existing problem will vanish
I also want to give a pat on the back to Cope Brothers engine shop in Tacoma, rebuilders of my engine. They did a superb job for a very reasonable price
  #25 (permalink)
Old 07-12-2006, 01:11 PM
BIB,
Throw that PCV away. It will contaminate the mixture. My 12 to 1, 670 hp 358 ci motor has tons of crank case preasure. I have dash 12 lines running off of each air cleaner to a seperate tank with 2 large breathers. Otherwise, I would have oil everywhere. I thought I had blow-by at first, but no it is just a lot of hp which creates pressure.
Scott
  #26 (permalink)
Old 07-12-2006, 01:16 PM
ByronRACE's Avatar
Default clarification...
Not knowing exactly what advice you're referring to, let me just clarify that my comment regarding the vacuum leak applies ONLY to carbureted engines. In your case, assuming you're using a speed density or alpha-n EFI system without a MAF...there is no problem letting air leak in to the vacuum side of the manifold as long as it's not so much that it creates an idle speed problem.
And, congratulations on getting it running well!
  #27 (permalink)
Old 07-12-2006, 05:50 PM
MAFS (Mass Air Flow Sensor?) included in the Holley package and thanks for the congrats.. it's raining today (this is the PNW!) but tommorrow she'll prowl the streets again!
  #28 (permalink)
Old 07-12-2006, 08:16 PM
ByronRACE's Avatar
Default I'm not clear...
I'm not clear on your response, but if your system has no mass air sensor measuring the air entering the engine, you don't have an issue with a potential PCV vac leak. The problem stems from allowing unmetered air to enter the PCV. Any unmetered air is air the processor doesn't know about...resulting in lean mixtures on mass-air systems.
  #29 (permalink)
Old 07-12-2006, 09:23 PM
To clarify, the problem was with "Blood Enterprises" in Auburn, WA , and not with the MAS or any other sensor or engine part...! It's operating fine now that a competent mechanic got his hands on the car!
  #30 (permalink)
Old 07-12-2006, 11:11 PM
Dominik's Avatar
good morning,
I once had a rebuild engine burning oil. At idle already there was plenty of blow-by past the rings exiting the sidepipes.
I advanced ignition at idle plenty (from 4 deg! to 20 deg) and it improved.
it appears that the too late ignition advance heated the top of the pistons up extremely causing the oil underneath to "cook" and move past the rings.
possible?
dominik
If I don't respond anymore, that's because I can't log in
  #31 (permalink)
Old 07-13-2006, 06:14 AM
Jerry Clayton's Avatar
Dominik
More likely is that the oily rich mixture burns slower and tha advanced timing lit it off in time to burn in the engine, not the pipes
Jerry
  #32 (permalink)
Old 07-13-2006, 07:46 AM
I really don't know why it looked like oil smoke before but there's virtually no smoke now that it's programmed properly, and the plugs looked OK and dry (just a little rich because the first shop had the ECU improperly programmed) when we checked the plugs after the distributor was replaced and timed properly. Not running rich or lean now, just perfect. All's well that ends well
Rate This Thread:
