Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 04-16-2007, 04:49 AM
Cobra Make, Engine: Midstates, 501
Question oil pressure and oil used
Guys,
Just looking for a little insight into what oil most guys are using and what kind of oil pressure you are getting. I have read about zink contents too any opinions.
Looking for type, wt, and pressure at idle warm and under different loads.
I think I may have a problem and want to compare notes.
Mike
Old 04-16-2007, 05:16 AM
BlueRooster's Avatar
Cobra Make, Engine: SPF #623 460/4x2
I use royal purple synth'. 10w40. My oil pressure has been pretty consistent at 45 over 2000 rpm and 25 at idle. In the heat of the summer it wants to drop from there so I have put in 20w50 which will bring it back to the numbers above. I never have a problem with the pressure at higher rpms, its always an idle issue.
Dane
Old 04-16-2007, 06:02 AM
Tom Wells's Avatar
Mike,
I use Castrol 20W50. Pressure is around 20-40 psi at idle (idle is gloriously lumpy), 55-60 psi at speed, warm. Cold is around 60 psi at all engine speeds. Takes a few minutes to warm up as it has an engine oil cooler.
Pressure gauge is mechanical and input is taken from the block rear center tap above the bell housing just behind and below the intake manifold.
I understand that the indicated pressure may be a bit higher at the tap on the front left side (facing forward) of the block just above where the mechanical fuel would go if I had one, since it's just on the output gallery of the oil pump, but I haven't checked it there. I use that tap for the ACCUSUMP.
I use a "normal" Melling pump. No high volume, no high pressure, no heavy duty. I'm too paranoid about losing another camshaft and distributor.
This combo has worked in the 521 for 18K miles just fine.
Tom
Old 04-16-2007, 07:51 AM
Cobra Make, Engine: SPF 545" stroked 460 - sold
Originally Posted by mjmacqua
Guys,
Mike
Hi Mike, I use Castrol 20W-50 and note 30 or so idle pressure and generally 55-60 range going down the road. Cold idle is higher. Initially I had a mechanical oil gauge which gave about these same readings, I have since changed to an electric gauge with sensor in the fitting at the driver's side front of the block. I have a remote oil filter and oil cooler setup and have a 20PSI switch out at the remote mount that will turn on a red dash light if oil pressure is ever 20 PSI or lower. It has never come on with the engine running. What are your numbers?
Old 04-16-2007, 10:22 AM
DavidinDurango's Avatar
If you are running flat tappets you need more zinc in the oil.
I use Rotella.
Guys,
Mike
DavidinDurango
mostly fords, with "some stuff"
Old 04-16-2007, 12:30 PM
wtm442's Avatar
Beam Me Up Scottie
Redline 20-50. Pressure between 50 and 60 psi under all conditions.
Warren
Old 04-16-2007, 01:00 PM
SuperHart's Avatar
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
Since I run a flat tappet cam in an early block I run Shell Rotella T 15W-40. That weight gives me 60 lbs. pressure. That stuff has the extra zinc to properly lubricate the cam and lifters. Usually find it at Pep Boys in the gallon plastic can.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Old 04-16-2007, 01:37 PM
Thanks to all.
My pressure seems a bit lower since I switched to 10W30 Syn. I think I am going to go to something a little thicker.
On a side note. I do not have the specs on the CAM (long story). Is there any easy way to tell if it is Flat Tappet with out pulling the whole thing out?
Mike
Rate This Thread:
