Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Like Tree4Likes
Old 03-07-2008, 08:49 AM
Tony Aprile's Avatar
Cobra Make, Engine: SPF #1358 Silver/Black stripes 466 2X4
I have a 460 in mine and have street driven quite a few small blocks with the most powerful being Roush 427R's.
The big block will give you plenty of low end torque, to the point where you could drive in high gear down to below 2000 rpms in traffic, the stroker small blocks definately make the power up top but do not like slow cruising in high gear. Not really a big deal..just an observation.
The sound of a big block will be a bit deeper in sound...depending on the engine..... Todays small blocks can run with the big blocks, there's no suprise there. Im sure a new SB Roush 427 can hold it's own aginst a mild 427FE or 460, but when you open the hood and see the Big Block ...there is no comparison.
Tony
Old 03-07-2008, 09:56 AM
Big blocks making 600 plus hp, bottom line if I do not see a dyno report, it has about 350 hp at the rear wheels. I get so tired of hearing "my mechanic said it about 575hp" then when the dyno it is about 325hp. I had a 502 in my old caddilac eldo, or 8.2liter and it was the biggest dog on the planet. I have seen 302's that put out as much as a mismatched 460 and you save 200 lbs of weight. As long as you have 427 cubic inches I do not care big block or small block, it is a SC427 so it should have a 427.
Old 03-07-2008, 12:53 PM
danc30's Avatar
Cobra Make, Engine: Hurricane HM1073 Keith Craft Genesis 427FE/482 CI
Originally Posted by madmaxx View Post
Big blocks making 600 plus hp, bottom line if I do not see a dyno report, it has about 350 hp at the rear wheels. I get so tired of hearing "my mechanic said it about 575hp" then when the dyno it is about 325hp. As long as you have 427 cubic inches I do not care big block or small block, it is a SC427 so it should have a 427.
You must have a small block.....
Old 03-07-2008, 12:59 PM
How about we do a honda 4 banger?
Bagram AF Afghanistan
Old 03-07-2008, 10:38 AM
tmareina's Avatar
Cobra Make, Engine: Unique #9159 428 FE 614HP by FE Specialties
I have a BB...nothing like it...performance is outstanding..sound is exceptional..sets off alarms as you drive by...and mine is set back about 3 inches or so and it makes a big difference in handeling...and, heaven forbid...you should want to sell it...you will get more for you car with the big block. In the end, however....it is what makes you happy...you have to live with it.
Tom
Old 03-07-2008, 11:16 AM
undy's Avatar
I have always longed for a high-winding moostang 302 donor ... but ....I'm stuck with this darn Kieth Craft 482" Pond aluminum side oiler.. I guess some things were just not meant to be..
Too many toys?? never!
Old 03-07-2008, 11:58 AM
Nantucket427's Avatar
Cobra Make, Engine: Superformance#1325, Miller Machine FE
Default Big Blocks rule!
I remeber when we use to debate this question but it was limited to one day a week or we would use up all the space on the site.
My only comment is; "to each his own"
Go to London, Ohio this Spring and count how many cars have the 427 emblem on the side of there cars. Not to many say 351 or 289 as a matter of fact the 289 guys usually don't put anything on the side of there cars.
Some people just can't handle a big block.
Everything has a downside, so dwell on the positives. Find humor in the tough times.
Old 05-19-2017, 03:27 PM
Cobra Make, Engine: Factory Five MKIV 331 Stroker carb'd
Has anyone found the stats on Carroll Shelby's Cobra wins.
How many races were won by small block Cobras vs Big Block Cobras.
Over the years I have read somewhere that most of the early races were won using the small block Cobras. And the Cobras with the V=Big Blocks were heavily modified as I understand.
Anyone have the REAL Numbers ???
FFR MKIV, delivery July 2010, Finished and a olling chassis and painted in Sept 2017.
Old 05-23-2017, 01:09 PM
so are as i am aware, it was the small block cars that won at international events. But these were virtually all Ace/289 type bodies.
Happy to be corrected.
Crendon 427, in the making
http://crendonreplicas.com/
Old 05-24-2017, 02:11 PM
cycleguy55's Avatar
I believe you're correct in that most Cobra victories came with small-block cars, but it wasn't that the big-block cars weren't as good as the small-block cars - the racing landscape changed as well
Brian
Old 03-07-2008, 11:56 AM
Cobra Make, Engine: Superformance MIII, Roush 427
My .02, I got the chance to drive a big block...it's everything everyone said it was. Great sound, power fall off in the upper RPMs and too much low end power for the tires to stand a chance. I then drove a small block stroker and found the upper power band was more usable while the lower tq off idle allowed for more chance to put the power to the ground. End result, I've got a stroker small block. Is it the end all...no way, I could use another 50-75HP so 4th gear would be as exciting as the first three.
-Dan
Old 03-07-2008, 02:40 PM
danc30,
I do not have anything right now although I am slated for a Roush 427. I did intentionally pass up on two SPF's with 460's that were substantially less cost. If I wanted a trunk engine I would buy a truck. If I wanted an engine that overheated on a regular basis I would get a BB, if I wanted to plow into every turn I would get a BB, if I wanted to scrape every speed bump I would get a BB.
Old 03-07-2008, 03:19 PM
danc30,
That pretty much tells it all !!!
Old 03-08-2008, 11:16 AM
Stentor's Avatar
Cobra Make, Engine: CSX 4000; Shelby aluminum FE with 58mm IDAs
danc30,
You are already going to pay a decent amount of coin for the Roush small block. Why not fork out a bit more dough and get an aluminum FE?
Then you can have the best of both worlds.
Old 03-07-2008, 03:38 PM
ZOERA-SC7XX's Avatar
To each his own, but as far as I'm concerned, size matters.
Old 03-07-2008, 05:24 PM
Cobra Make, Engine: bennett
thanks for all the input ,i guess i will be happy with either.you cant make a bad choice,it will still be a cobra,i'll probably bo big.
Old 03-07-2008, 05:49 PM
fkemmerer's Avatar
Cobra Make, Engine: ERA, FE BBF
Smile
There's no replacement for displacement. 482ci Ford FE.
Old 03-07-2008, 06:15 PM
Cobra Make, Engine: classic roadster,408cu
I bet if mr Shelby had what we do today in 1966 he go with a small block , only the Minnow needs that boat anchor in the front.
Old 03-07-2008, 06:18 PM
1Cobrat's Avatar
Cobra Make, Engine: Scratch built Bowtie, C4 suspension, Fiberjet body, 427 Rat
Smile
This really is a personal choice. I have always imagined a big block in a cobra. Just my preference and I've always been a small block guy. I've seen plenty of small and big blocks, they each have pros and cons depending on what you are looking for in a car. I wanted an earth rumbling, head jerking, engine compartment filling big motor. However, a fuel injected 5.0L that gets 20mpg has appeal as well. I haven't heard that saying in years, "There's no replacement for displacement" I love it. . . . Good luck deciding.
Old 03-07-2008, 07:45 PM
Cobra Make, Engine: Cutting Edge, Boss 429
Just broke my aluminum drive shaft in half
A nice little small block is sounding better at the moment
