Go Back   Club Cobra > Club Forums > AC Cobra
Old 02-09-2005, 05:03 AM
Base733's Avatar
Cobra Make, Engine: Unique 351W
Default Dynos in the Atlanta Area
Hey-
I have a Unique with a stroked 351W that is running poorly and needs a diagnosis. I saw a thread a while back about dynos in the Atlanta area. Did any of you guys ever find a dyno shop with a knowledgeable operator/mechanic for carb tuning?
Thanks for the help!
Old 02-09-2005, 05:41 AM
marcocsx3121's Avatar
Cobra Make, Engine: Owned CSX 3121 1969-1975. Went to the dark side and bought a 'Vette. May yet repent and be saved.
Try Lamar Walden Automotive in Doraville, 770-449-0315. These guys have been around forever, originally making a name for themselves with Chevy 409s in the old, old days.
Old 02-09-2005, 06:53 AM
GeorgiaSnake's Avatar
Cobra Make, Engine: Sold - Unique FIA - SA 396 Stroker
JO and Tony Radford have used someone local and speak highly of them.
Randy
Sold the Unique - Bought a Porsche TT - Sold the TT - Bought a truck
Old 02-10-2005, 05:10 AM
Base733's Avatar
Thanks!
Old 02-10-2005, 03:43 PM
Cobra Make, Engine: 2 dr roadster, V-8, 4 spd.
If this is a sudden problem, I'd suggest hooking it up to a diagnostic Sun machine first. On my Mustang, we solved 85% of what I thought was a jetting issue via a valve adjustment and ignition tuning. I can recommend someone who has one of these at their house (he does charge for it, but $60 will buy you an hour and he is local to Roswell), before you spend the $$ on dyno time. He is also an absolute carburetion magician and is well known amongst the Shelby Mustang crowd. IMO, dyno time is meant to squeeze out that last few percent. The Sun machine can cut out one cylinder at a time too, which can reveal issues down to a cylinder level. Just my 2 cents.
Old 02-10-2005, 05:28 PM
Base733's Avatar
The problem is a bit of an erratic response when opening the throttle. Sometimes it hesitates and other times it doesn't. The carb was recently rebuilt with all the gaskets and power valve replaced. The accelerator pump was also looked at and seemed to be working fine.
I thought that the dyno might be able to diagnose the problem but maybe the Sun machine is a better solution as this is not a fine tuning type of issue.
Old 02-10-2005, 05:59 PM
What carb are you running? I had similar issues with my Holley and fixed it without a dyno or Sun Machine.
Randy
Old 02-10-2005, 07:48 PM
Take it to GeorgiaSnake's house 1st now that he volunteered.
Old 02-11-2005, 04:27 AM
That will work, however if you just want to dismantle it go to TC's
Randy
Old 02-11-2005, 04:33 AM
Base733's Avatar
The carb is a Holley DP 750 pro with mechanical secondarys. GS, what was the solution for your carb?
Old 02-11-2005, 04:42 AM
My secondary is vacuum - that was the problem. I experimented with different springs until I found the right combination. I also experimented with jet sizes.
Looks like the Sun Machine is your answer.
Randy
Old 02-13-2005, 05:43 AM
Cobra Make, Engine: former Unique289
...replace the stator, right Randy? ....
....or for the best way to fix a Holley;
step #1: replace with a Barry Grant Demon Carb...
step #2: .... there is no step #2.
chill
Old 02-13-2005, 05:49 AM
You must be feeling better
"Statorman"
Old 02-13-2005, 05:53 AM
yep. even got my garage flooring down yesterday, will post picture later.
chill
Old 02-13-2005, 09:05 AM
HSSS427's Avatar
Cobra Make, Engine: ERA #414 427 s/o w. Shelby Aluminum heads, Edelbrock Performer RPM Intake, Mighty Demon 750, Tremec TKO 600
Default TC, who's the secret Sun source?
I've just rebuilt my Holley 750 Double Pumper. I bought a Proform main body to replace the stock main body. It doesn't have a choke, but the choke horn is still on the main body, so instead of cutting it off, I just got the new body for $99. I also changed jet sizes (smaller) and accelerator pump shooter sizes (larger). I think I'm also going to put the 50cc accelerator pump diaphragm on the secondaries. Have also bought the Proform billet throttle plate. So basically I've done a Dr. Frankenstein on my carb and now need to see if it "lives!"
Was intending to go back to Balanced Performance in Buford to have it dynoed, but the option of using the Sun plus someone who knows carbs sounds like a better idea. Plus I'd love to see what kind of 'stangs he has. BTW, what do you have? Gowing up, it was my neighbor's 67 Shelby GT 500 that got me hooked on Fords and introduced to Cobras. Can you email or post the contact info?
Thanks!
Scott
