Go Back   Club Cobra > Club Forums > AC Cobra
Old 06-01-2005, 04:04 PM
Default crane cam ?
Have a 428 with a good idle cam , part no. 343801. Been thinking of going to a more lopy idle. Not interesred in racing but like a more rough idle. A friend came up with part no. 344561. There both crane. Any advise on a selection.
Pat
Old 06-02-2005, 09:49 AM
CJ428CJ's Avatar
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
If you want a nice lopey idle, in general you want to select a cam with a smaller lobe center angle. Your choices generally run from 108 degrees through 114 degrees. 108 degrees will give you the most lumpy idle while 114 degrees will give you the smoothest idle (all else being equal).
Chris
Old 06-02-2005, 11:38 AM
Cobra Make, Engine: shellvalley 428 ford
CHECK OUT THE CRANE WEB SITE AT CRANE CAMS.COM .THEY HAVE ANOTHER CAM THAT SAYS FAIR IDLE. GENERALLY, WHEN CRANE SAYS ROUGH IDLE THAT IS YOU HAVE. GOOD LUCK
BYRON W.
Old 06-02-2005, 03:05 PM
Thanks Chris and Byron for responding.
Pat
Old 06-02-2005, 06:05 PM
HEY OLBLUE66, YOU ARE VERY WELCOME. ALSO, DID SOME CHECKING ON THEIR RESPECTIVE WEB SITES AND THE CRANE CAM YOU REFERENCE AND THE EDELBROCK PERFORMER RPM HAVE IDENTICAL SPECS. I HAVE HEARD THE EDELBROCK AND IT SOUNDS GREAT AND RUNS GREAT IN A 427. MIGHT USE IT MYSELF.
GOOD LUCK, BYRON W.
Old 06-03-2005, 02:48 PM
Well BYRON , I called crane and talked to them. He advised me to go with a special grind came that they would make. It would give me the same performance the other cam has [ would't loose the bottom end either] Would add more duration giving more lopy idle.
Old 06-03-2005, 03:42 PM
HI OLBLUE66,
SOUNDS GOOD. WHEN YOU GET THE CAM MAYBE YOU COULD POST THE SPECS AND TELL US HOW IT IT SOUNDS AND WORKS.
GOOD LUCK AND THANKS FOR THE UPDATE.
GOOD WEEKEND
BYRON W.
Old 06-04-2005, 07:02 AM
Tony Radford's Avatar
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
One of the challanges I gave Bill when he designed my stroker was just that, an awesome idle. My lobe center spacing is 107 degrees. I have to adjust my doors a lot.
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
Rate This Thread:
