Go Back   Club Cobra > General Discussion > Advertisers Forum
Old 05-10-2011, 12:17 PM
Default 460ci.FE Engine Special $11,995.00
Fully Machined 428 block
Stock 428 crankshaft offset ground 4.200 stroke
Scat 6700 I-beam rods
Diamond Custom pistons 10.1 compression
Clevite & Fed-Mog bearings
Pioneer SFI Damper
Comp Cams Custom Grind Camshaft
Morel Hyd.Roller lifters
Ford Racing timing set
Stock front cover & pointer
Melling High Volume oil pump
ARP oil pump drive
Moroso T-Style oil pan pick up & dip stick
Edelbrock Aluminum CNC Stage II heads set up complete
T&D Shaft mounted Race series rockers
Comp cams push rods
ARP Head bolts
Original police interceptor PI intake port matched
Edelbrock Aluminum water pump
MSD Dist. & KCR plug wires
KCR Logo finned valve covers
Fel-Pro Gaskets
Quick Fuel 780 carb
Bal.Blueprinted & Assm.Dyno tested & tuned
Please call with any questions 870-246-7460
Keith C
Old 05-10-2011, 12:39 PM
Keith,
Crank is cast-are rods and pistons too? Approximate power levels and cam specs?
Chas.
Old 05-10-2011, 01:23 PM
The Rods are Scat 6.700 I-Beams, Diamond pistons are forged.
This engine should make 550/560 on power. The camshaft is a
custom grind from comp. It will be like 236/242 @50 on a 112 lobe.
Keith C
Old 05-10-2011, 02:48 PM
xlr8tr's Avatar
Cobra Make, Engine: CAN-AM cobra, 460 SVO
with this kind of setup, what would it idle at, and what would you set rev limiter at?
Mark
Old 05-12-2011, 09:38 AM
This engine will idle around 900rpm. It will make max horse power at 6000rpm. You would run a 6000 chip.
Keith C
Old 08-07-2011, 09:47 PM
This engine is finished and ready to go. We can send complete dyno sheets on the engine. Made 570HP and close to 600 ft/lbs of torque. engine is complete and ready to go.
Thanks, Keith
Keith C
