Go Back   Club Cobra > General Discussion > Advertisers Forum
December 2025
Old 07-18-2011, 12:27 PM
Default B2 Motorsports 445FE Short Block
Got most of the parts in the shop, ready to custom assemble based on the customer's request.
*C7ME-A 390 Block, Bored/Honed, Align Honed, Square Decked, Freeze Plugs, Cam Bearings, Painted
*ARP Main Bolts
*Eagle 4.250" Crankshaft
*Scat 6.700" I-Beam Rods
*Probe Forged Pistons, Dish
*Mahle Rings
*Clevite Main/Rod Bearings
*Rotating Assembly Internally Balanced
*Customer's Choice of Comp Cams Camshaft, Degreed
*ARP Cam Bolt
*Ford Racing Timing Set
$3565, with Comp Cams solid or hydraulic flat tappet cam
+$200 for Comp Cams hydraulic roller camshaft
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 07-18-2011, 01:49 PM
RodKnock's Avatar
[deleted text]
I would hope that anyone seriously considering buying or building an engine, or what have you, would certainly give you a call or email for more info. I would.
Old 07-18-2011, 03:38 PM
[deleted text]
He truly has a legion of guys that are satisfied customers and come on here to say so. [deleted text] A class guy.
Chas.
Old 07-19-2011, 06:35 AM
Clois Harlan's Avatar
Hey Brent, I am not in the market yet but I am thinking of pulling my original 427 and storing it. I might go with a 390 stroker like you have. What is the bore on the referenced block and what oil pump are you installing? What compression will those Probe pistons be designed to run.
Clois
"Let's roll"
"Be part of Something Good
Old 07-19-2011, 07:03 AM
Clois,
The 445FE bore is based on a 390 block, so it's usually a .030" or .040" over 390...which is a 4.080" or 4.090" bore size.
I run Melling HV pumps.
The Probes are available in two flavors, dished (18cc) or flat top (4cc). With the typical 72-74cc chamber sizes from Edelbrock and a zero deck setup, you're looking at around 10-11.5:1 SCR. I can also do Diamond pistons and put the SCR wherever you need it to be.
Rate This Thread:
