Old 10-02-2009, 08:23 PM
BeasleyRB's Avatar
Cobra Make, Engine: B & B , 351W 400+
Default Cleaning Aluminum intakes??
What product works best to clean discloration from an aluminum intake manifold? Last year we had a very cool overnight temperature then a very warm and moist front came through. Water condensed on almost everything in my shop including my cars engine. That resulted in brown spots from the condensed water on the intake manifold. What can I spray on the aluminum parts that will clean them without being too agressive on other metal parts in the engine bay? What has worked best for you? Thanks
Old 10-02-2009, 09:08 PM
thudmaster's Avatar
Regularly Offensive
Cobra Make, Engine: spf
Carb cleaner and rags. Lots of rags on everything.
Ed
Too close for missles, switching to guns.........
Old 10-02-2009, 10:08 PM
Mike Bartlett's Avatar
Cobra Make, Engine: CSX4771-CF. 1966 427 S/O
Neutral
Not sure if your intake is polished or just rough? Mine if rough but to keep in clean I have used carb cleaner and also Acetone and a small brush.
Mike
Rubber peelin' gears a jammin'!
Old 10-03-2009, 06:51 AM
PatBuckley's Avatar
Try Simple Green.
Old 10-03-2009, 07:38 AM
kgs365's Avatar
mothers aluminum polish...used it on my aluminum edelbrock rpm intake to clean up rust marks etc..took them right off seemed to bring it back to original
Old 10-03-2009, 08:23 AM
I just remembered I have used brake parts cleaner as well which does a great job to get the really stuck on stuff.
Mike
Old 10-03-2009, 01:25 PM
427 sam's Avatar
Cobra Make, Engine: Dax -fuel inj 383 chevy
Send a message via Yahoo to 427 sam
Hi here in the uk we have a company called Frost who i am sure will export to the us and there one grand range is very good. web page is www.frost.co.uk Sam
Old 10-03-2009, 01:29 PM
Beretta92's Avatar
Carb Cleaner...if the stains are tough then...Brake Clean or acetone are perfect.
BEWARE THEY WILL DESTROY ANY PAINTED SURFACE.
Mothers aluminum polish for polished manifolds... not for "As Cast"
Old 10-03-2009, 02:32 PM
"Q"'s Avatar
"Q" "Q" is offline
Cobra Make, Engine: 383 Stroked and Blown Chevy powered Cobra
Smile
Deoxidine rust remover (purchased at local hardware store) worked wonders for me. Applied it to the intake with a paint brush, waited a hour or so, rinsed the intake with water and dried. Got the original finish again.
Ps. Also worked great on the stainless side pipes to remove the yellow discolouring due to heat. Same process used as above.
