11-05-2009, 11:53 AM
Cobra Make, Engine: SPF#0760
Randy,
Are these Trigo or WAW...If Trigo's I'm interested...(Note to everyone - the ko's are different and not totally interchangable)
SPFWiringDiagrams@Comcast.net
11-05-2009, 11:55 AM
More Stuff...
Please add a new Duraspark ignition module to the list of available items...
11-05-2009, 03:55 PM
Banned
The list is growing nicely...hopefully others needing some of this will chime in (and update it, accordingly.)
Which gets to the age old struggle of wants vs needs. Example: I really want an extra AC logo'd center cap to have on hand in the event that I lose one and find myself needing it. But since I don't really need it at the moment, I'm not going to PM vanoochka for one of the two he is offering up. It would just move from his tool cabinet to mine...not much benefit.
Just please keep this in mind when you see something that catches your eye. Otherwise, the hoarding mentality that is in most of us will short sheet the one enthusiast out there that might actually need it more.
-Dean
11-05-2009, 04:07 PM
-Dean
Too funny!! I thought the same thing when I saw Vanhoochka's (Chuck's) post about the center caps. Don't need...but I might need someday.  As you said Dean, no need to just be moving stuff between garages if it's not going to be used.
Doug
11-05-2009, 05:59 PM
Ca.
I agree 100 per cent.........
11-05-2009, 06:18 PM
Ca.
I found in my garage a NEW rotor,cap,and wire cover fo the Accel HEI for an FE.
the kit part # from Summit is ACC-8348 they are NOT in the proper box because
i changed over to the stock GM points type cap and rotor.
they came with my dist. when it was new.
again i have the ROTOR, CAP, and the PLUG WIRE COVER new never useed.HEI style
11-05-2009, 09:36 PM
Ut
Count us in! I'll start digging around tomorrow. I have a feeling we have a lot of parts we can throw into the pot.
11-06-2009, 02:31 AM
I'll take that Kirkham roller you have sitting over there in the corner of the shop that you just don't know what to do with .. already got the TKO and 482 ready to go
Too many toys?? never!
11-06-2009, 05:24 AM
DE
Cobra Make, Engine: Classic Roadster, 302, roller cam, Holley 650
David, That was a VERY interesting email. I would bet that you might have a few more bits than the rest of us have.
The one line never heard in heaven; "Gee, I wish I had spent more time in the office."
11-06-2009, 06:05 AM
Member of the north
Cobra Make, Engine: A Cobra
Dang, if you round up all the engine parts for an FE, you could have near complete engine.
Dean, wake up!
11-06-2009, 06:25 AM
Originally Posted by Nope It's Fake
Don't forget these on the list of "availables."
Two pair of early 289 heads to whoever is in need of OEM castings. I can provide the casting numbers and dates if necessary.
Chris....... I'll take them.
I have an assortment of felpro gaskets, a 4 wire alternator, and some other stuff. I'll confirm everything this weekend.
Steve S
F-250 w/ 6.4 Diesel
11-06-2009, 07:32 AM
Banned
Gosh, David. Even your throw-aways are going to create a stampede!
I just hope that everyone stays true to the cause. Thanks for offering up some bits for those that truly need them!
-Dean
11-06-2009, 08:14 AM
Member of the north
Here is the new list. If you are accepting something, please post it. If you were missed, please post it. If you are adding something, please post it.
Dang, all this stuff and no takers.
1. Superformance front marker lenses, clear/white type (Lucas with fluted lense and chrome trim ring); 2 pairs available (see Dean or Rodney)
2. 2 Piece Rear Seal kit for a 351 Windsor; 2 kits available (see Blas).
3. FE/Windsor March Performance 2 groove water pump pulley; 6" dia hi-flow model; part# 1562 (see undy).
4. I have both a 16 and 17 tooth driven speedo gear for a Tremec T600. Let me know if anyone needs them. I could send by next week and will even cover postage (see DCDoug).
5. 2 round red tail light lenses that are glass they say "England" and have the number 488 on them; have the 2 trim rings that go with them these are the ones that the rubber grommet holds them in place (see RustyBob)
6. FE engine (complete) in the back of the barn off my crane. (see trularin).
7. SROD 4sp top loader (3sp w/overdrive) with shifter. Whomever wants it pays shipping from Manteca Ca. 95336 - (see tcrist)
8. 3550 (with shifter) that has a crack in the main case that you can use for parts. Not sure what shape it is in because it was given to me. Whomever wants it pays shipping from Manteca Ca. 95336 - (see tcrist)
9. 99% of the complete stock heater assy "used" for a CRL C427 (see Terry).
10. set of stock ceramic coated SPF side pipes. They need some cracks welded up. (See Silverback51).
11. Two pair of early 289 heads. (See Nope It's Fake) ***************** See below
12.Two wheel center caps as sold by Finishline, each aluminum with AC logo. (See vanoochka )
13. Original-look shifter (replaced it with a Jordan) off of a Tremec TKO. (See vanoochka )
14. Steering wheel center cap (small nick) with AC logo. (See vanoochka )
15. One set of 4 aluminum Trigo knock-offs - these are the knock-offs only, no adapters or wheels. ( See Randy Rosenberg )
16. A new Duraspark ignition module. ( See Blas )
17. I have the ROTOR, CAP, and the PLUG WIRE COVER new never used for FE? ( See rustybob )
Would LuvDaBlues please confirm you have taken the heads. What will you pay forward?
11-06-2009, 08:45 AM
Ca.
Is there any way these parts could come together to assemble a Cobra that could be raffled off or auctioned off for some kind of cherity????????
i like the pay it foward concept and i think it will work well once we get the hang of it...
but i would think there is a cherity out there that could benefit from OUR generosity.
11-06-2009, 09:00 AM
Anyone have an old dingy SOHC engine lurking around in the back of their garage? I'd be happy to take that off your hands.
I'm going to search the garage this weekend and see what I can find.
11-06-2009, 09:30 AM
IL
Cobra Make, Engine: FFR with '94 SVT 5.0
LuvDaBlues - They're yours; PM in your box. I'll get the casting numbers to you over the weekend.
Later,
Chris
FFR Mk3.1 #7074 - Start Date: 10/11/09
11-06-2009, 09:34 AM
IL
Vanoochka - I'll take the shift lever if it's still available (sent you a PM). I'll post something in return after I take another look through my stuff.
Thanks!
Later,
Chris
11-06-2009, 11:12 AM
I'll take the heads and sort through some items this weekend. Gaskets, alternator, misc. stuff.
Steve S
F-250 w/ 6.4 Diesel
11-06-2009, 01:20 PM
Member of the north
11. Two pair of early 289 heads. (See Nope It's Fake) ***************** Gone
13. Original-look shifter (replaced it with a Jordan) off of a Tremec TKO. (See vanoochka )************Gone.
11-06-2009, 01:53 PM
Cobra Make, Engine: Contemporary Classic CCX 3970: 1965 427 Cobra S/C, Shelby aluminum 427 CSX 290 (468 cu in) engine
OK, here's something for a really special person. Almost complete 390FE engine bored out to 428 cu in. Gouge in one cylinder where wrist pin lost its retainer and moved a little.  All ya gotta do is pick it up and haul it away. If you aren't able to sleeve block cheaply, the block would make a great planter. Bay Area location. Rich
