November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 12-06-2009, 08:13 AM
mdross1's Avatar
As you move your spring collar up, your car will go up higher as well. But it's not a 1 to 1 ratio. Meaning if you want to move your car up an inch you will move the spring collar up by less than an inch -- maybe three-quarters, maybe two-thirds, but you get the idea. That's on my car, though. Your car's spring to results ratio will be different, but still similar.
EDIT -- After getting your ride height perfect you should do final adjustments with your car on scales. Getting your corner weights just right makes a tremendous difference in the way the car drives.
Exactly,what should be done, have the car scaled.It will never be right if you don't.Ask me how I know?
Old 12-06-2009, 08:52 AM
Default Scales
This is what we used. DCDoug and I had a thread just recently about renting corner weight scales. But almost every local Cobra Club has somebody that actually owns a set (and you only need them for the afternoon). Fill your tank up about half-way, put something in the driver's seat that weighs what you do, then adjust to try and get a 50/50 cross-weight. Don't forget to loosen your sway bars first -- the pre-load will skew your numbers.
Display Modes
