Old 01-13-2010, 02:21 AM
BCBCobra's Avatar
Cobra Make, Engine: Street Beasts with a 302 mildly worked over. I purchased it semi-complete and have enjoyed working on finishing it.
Question Bump Steer, what is It and how to fix It?
I hear so much about "Bump Steering" and see the adds for parts, but how do you know what Specs to use to correct it? I have a Street Beast Kit using a 1990 Saleen Mustang with coil over shocks in front. It rides very hard and stiff in front w/o having a sway bar. It does not wander going straight, but it does have a bump when turning on a rough surface. This is my first posting I hope I did it right. Any help or ideas will be appreciated. Thanks, Harold B.
Old 01-13-2010, 02:51 AM
If you drive straight line and car go straight when only one front wheel go over bump you don't have a bumpsteer problem.
So I think that you have some othere problem (like too stiff springs/suspension for rough surface).
More about bumpsteer info http://www.ffcobra.com/FAQ/bumpsteer.html
-jberg
Old 01-13-2010, 04:04 AM
mdross1's Avatar
When the steering linkage angle is off enough,so that when you hit a bump the front wheels move without you moving the steering wheel,you have bump steer.It can be corrected in a couple of ways.The secret is to get the tie rod ends coming out of the rack to be parrallel with the rack, and with the car sitting on the ground.
Old 01-13-2010, 05:24 AM
mickmate's Avatar
This is good reading on MII geometry http://www.heidts.com/support_suspension_101.html
mickmate
http://www.actoncustom.com/
Old 01-13-2010, 06:38 AM
lovehamr's Avatar
Stolen Avitar
If the springs that you are using were intended for a 3500# Mustang with 65% of the weight on the front wheels then they are about 3X to stiff for your 2400# Cobra with 50% of the weight on the front. Might talk to SB and see what they recomend for spring rates.
Steve
