Old 04-18-2010, 04:58 PM
Cobra Make, Engine: Kirkham/Southern 427 SO finally on the road
Default FE water pump pulley
My Kirkham/427 SO/Southern has always run hot at low speeds, like in town, light-to-light and at idle. There's no question it's an airflow/radiator issue. I believe I started with a 7" pulley and, at someone's suggestion, I switched to a 5 3/4". Now I've been told that it spins too fast and is causing "cavitation" and I should go back to the 7" (which, foolishly, I sold on eBay). Before buying another pulley, does anyone have a thought on this? The car has an Edlebrock high flow water pump. Thanx steve
"Never enough time to do it right, always enough time to do it over"
steve meltzer
"I may be wrong, but I'm never in doubt"
Old 04-18-2010, 05:40 PM
CC Member / Sponsor
More important than the diameter of the bottom pulley is the ratio of the bottom pulley to the water pump pulley. We have found that a 1 to 1 ratio works very well on most engines.
Having the water pump pulley over driven will only cause problems at high engine speeds. It will help at lower engine speeds.
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
Old 04-18-2010, 06:47 PM
Tom, Thanx. steve
steve meltzer
