November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 06-07-2010, 09:23 AM
Cobra Make, Engine: SPO 2644 Roush 427R
Cobrarob
We installed the harness this weekend, works great. Hi Tech thought ahead and drill the upper frame support and also slit the fiberglass. You need to get a Y harness I got a pair of Simpson cam locks they work great.
Jack the car and remove the rear tires. Look up under the shock mounts you will see a frame cross member about the same height as the back of the seats. Find the slit in the fiberglass and cut thru from the back with a razor blade. The holes need a 3/8" x 3" bolt (2) large washers, lock washer and nut. You have to install the bolt from the top due to an angle cross member below. Open end wrehch for top and ratchet for below.
On the floor you will need to remove the seats. SPF has eyebolts on the floor and you will need to install 7/16" x 2" for the lap belt mount.
This only takes about 45 minutes and I saved 650.00 from having the dealer install.
Hope this helps
Rick
Display Modes
