Old 05-27-2010, 01:57 PM
boris_thespider's Avatar
Cobra Make, Engine: B&B, 1969 392w, Tremec TKO
Question Screeching master cylinder?
Whenever I jam down hard on the brake pedal, there's a loud screeching sound. It sounds like it's coming from the master cylinder. My car isn't even on the road yet. This happens when I'm just sitting in the garage. I have a lot of pedal and the brakes seem to be functioning properly. Anyone ever hear of a problem like this or have any ideas on how I can figure out what's going on? Thanks...
Old 05-27-2010, 03:05 PM
Is there any brake fluid in the reservoir?
Does your cat like to sleep around the brake pedal linkage?
Old 05-27-2010, 07:46 PM
Sometimes I'd like to put the cat under the brake pedal
To answer your first question, yes... the fluid reservoir is full.
I was reading on some 4x4 forum where a guy had the same screeching master cylinder and he seemed to think that there was still air in the system. Can air in the master cylinder make screeching sounds if you jump on the brakes real hard. If I press the pedal normally there is no screech.
Help!!! Brake experts needed!!!
Old 05-27-2010, 08:05 PM
Bob In Ct's Avatar
Is the noise continuous as long as the brake pedal is being pressed?
Old 05-27-2010, 08:16 PM
No it isn't, Bob. It's just a short, loud squeak near the bottom of the pedal stroke.
Old 05-27-2010, 08:43 PM
sounds like it still has air in the sytem.....
do your self a favor and by a good brake
bleeder pump.....it will save you time and agravation........
If you're sure it's coming from the master cylinder, the only thing moving is the piston inside the cylinder. It must be scraping against the side of the cylinder walls. If so, time for a new master cylinder.
Old 05-27-2010, 08:50 PM
McD00's Avatar
Cobra Make, Engine: 931 mangled in parkinglot incident - traded for new house roof <sob>
Its the tires skidding on the pavment....duh.
McVette
"...Just Shut the phuque up and Move on please..."
