December 2025
Old 10-31-2010, 07:12 AM
zrayr's Avatar
Cobra Make, Engine: Fords
from my experience with Hylomar, you won't have any trouble with slippage. It is extremely sticky. I use the Hylomar Racing Formula, which is the one that Permatex markets for them.
http://www.permatex.com/products/Aut...ge_Sealant.htm.
http://www.hylomarsealant.com/_resou.../products.html
You will find out about the sticky factor when you try to get it off your finger w/o resorting to caustic gasket remover.
Z.
'65 K code Mustang
'66 Galaxie 500
Old 11-01-2010, 11:55 AM
Snakebit's Avatar
Club Cobra Member
Cobra Make, Engine: ERA 289 FIA #2100 Rio Red Wimbledon White Stripes 302 stroked to 331 Webers Richmond Road Race 5 speed
The SCE gasket is .120 thickness instead of the standard .060. It is made for standard ports, so you have to trim the port openings to fit your heads. The SCE part number is 136106 for a small block Ford
Snakebit
Old 11-17-2010, 08:19 PM
wrogers55's Avatar
Cobra Make, Engine: Backdraft #318, 418 CI, 532 RWHP, Mass Flow Injected, TKO600-Road Race, BMW M3 Suspension, Race Springs (Wouldn't do it again, rough on the street).
Default All fixed and this should close this post.....
It's fixed. It runs perfect. No black center plugs, no smoke from exhaust and it idles back down immediately.
For those of you having the same oil consumption/ middle two black plugs, pinging at low speed acceleration.....a new intake gasket fixed the problem completely. Installed it with Hymolar racing blue. Stickiest stuff known to man.
The last issues was refilling the cooling system and getting rid of the air. Lots of posts on strange ways to do it on a small block. After a bit of frustration, I just decided to unscrew the water temp sending unit on top of the manifold and fill the tank until water came out of the sending unit hole. Screwed the thing back in and haven't had a problem since. Water level and temp is perfect.
Thanks for all the help and advice. Taking that thing down to the open valley with the motor in the car was the easy part......unplugging and plugging back in the FI system was a challenge, but I learned a lot. She is good to go and I'm back on the road. Yahoo.
Wayne
Wayne Rogers in Hideaway, Texas
Old 11-19-2010, 10:31 AM
YerDugliness's Avatar
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
Congratulations, Wayne!
Cheers from Dugly !!
YD,E./PNB
No names were changed to protect the innocent!
Display Modes
