Old 06-30-2010, 05:28 PM
cobrakiwi's Avatar
Default Windage Tray needed
Hi
Any body have a windage tray for the Aviaid oil pan they would like to get rid of?
I need one for my build, got the pan just need the windage tray.
Old 06-30-2010, 07:41 PM
mickmate's Avatar
Do you need the pan that bolts inside the oil pan or the tray that sandwiches between the pan and the block?
mickmate
http://www.actoncustom.com/
Old 06-30-2010, 07:43 PM
cobrakiwi's Avatar
The tray that goes between the block and pan,
Old 06-30-2010, 09:10 PM
mickmate's Avatar
I use these http://www.summitracing.com/parts/FMS-M-6687-A390/
I put a hole in them for the pickup brace to go through.
mickmate
Old 03-10-2011, 09:12 AM
Send a message via AIM to aviaid
Try the source.
John Schwarz, President
AVIAID Oil Systems
(818) 998-8991
Old 03-10-2011, 09:23 AM
Jerry Clayton's Avatar
Good to see you on here John, this is probably the largest collection of people that should be using your stuff.
Jerry Clayton
Keeling & Clayton California Charger
Old 03-10-2011, 02:09 PM
MaSnaka's Avatar
The windage tray listed from Summit is listed as N/A (not availible). I had heard ford discontinued them.
Old 03-10-2011, 02:28 PM
We make our own part from 16ga steel, weld in directional screen in the 4 rod throw windows, and make provision to bolt on our custom pickup. The assembly is then Cadmium, not Zinc, plated. The part is sized so that once everything is assembled you can lay a bead of clear silicone, our sealant of choice, on the gap between the pan and the block all the way around the outside, then with your finger smooth off the excess al the way around, just like caulking tile. If anything leaks once that's set up, it' sthe rear main seal.
Credit for that method goes to Tony at Keith Craft.
AVIAID Oil Systems
(818) 998-8991
