| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
09-18-2010, 01:31 PM
CA
Oil Drain Plug Gasket Suggestion
I changed the oil on my Roush 402 and installed a new copper washer on the oil drain plug. After test driving it (test drove, cleaned the area thoroughly, and test drove the car again) I noticed some seepage around the drain plug.
It's not even enough to drip on the floor and I know it's not coming from another source. The drain plug can't be tightened any more.
Anyone have any suggestions for another type of gasket (rubber?) or a gasket to use in conjunction with the copper ring? Maybe a little dab of high temp RTV?
Doug
09-18-2010, 02:10 PM
Sometimes that seepage stops by itself after a couple of heat cycles, so don't rush. If it continues to seep, I've had luck with Dorman's rubber/steel combo. Available from Summit.
09-18-2010, 03:39 PM
CA
Thanks Patrick. I'll put some miles on the car and see if it stops by itself.
Doug
09-18-2010, 04:14 PM
MI
Cobra Make, Engine: Former owner of SPF#2632
Doug - guess what...mine does the same. Only when I really inspected it looks like the drip is actually coming from the threaded fitting plug (some us it for the oil temp gauge) and wisking back a few inches. Never actually forms a drip so i am not touching it. This fitting is on the pan a few inches forward of the oil drain plug on the drivers side.
09-18-2010, 04:30 PM
KS
Cobra Make, Engine: jbl
work it a couple times back and forth to get the parts to wear together then put the final torque on it and see if it holds. soft aluminum washers work also.
09-18-2010, 09:38 PM
CO
I use a thick rubber gasket from NAPA. No seepage at all.
09-18-2010, 09:42 PM
PA
i had the same issues with my canton pan drain plug, no matter what gasket i used it seeped. i wrapped the threads with teflon tape problem over. it takes a minute extra but it never leaks.
Fred B
09-19-2010, 06:17 AM
NJ
I installed a permanent quick release fitting. I never have to remove the drain plug. I simply remove the protective cover and snap on a drain hose.
Roscoe
Roscoe
09-19-2010, 07:49 AM
CA
Bob - Do you use the the thick rubber gasket alone or with a copper gasket?
Anyone know what size the drain plug is on Roush 402? I just changed the oil and don't want waste it measuring the plug.
Doug
09-19-2010, 08:56 AM
CO
Just the rubber gasket all by itself. I don't use any thread sealer, either.
09-19-2010, 09:13 AM
NJ
This is the quick release system from Aeroquip.
Roscoe
Roscoe
09-19-2010, 11:40 AM
Ca
GM uses a Aluminum washer 1/2" with a rubber insert. Available at any GM dealer, maybe NAPA too? Ford uses something similar on there vehicles with aluminum oil pans.
Rick
09-19-2010, 05:23 PM
CA
Thanks for all of the suggestions. I went down to the Napa store this morning and the parts guy brought out a drawer with a bunch of different types of oil plug gaskets. They had the Dormand, but the diameter of the copper ring was too large to be effective.
I ended up finding a rubber gasket (Napa PN 704-1964) that fits tightly around the oil plug with a perfect diameter to accommodate the copper ring and the pan surface. I put the rubber gasket on first, then the copper ring, the the oil plug.
Seems to be working so far.
Doug
