| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
10-18-2010, 06:09 PM
CA
I'm no expert, but I wouldn't make a habit of blending different oil types. Most builders recommend that you run a motor for 3k miles on dyno oil before running a synthetic.
Who built your engine? What do they recommend?
Doug
10-19-2010, 05:12 AM
KY
That would be me....I guess he couldn't get a hold of me last night.
Mark, I'd rather you not use synthetic oil at all in this engine. I like the higher viscosity/higher oil pressure.
As for mixing, you can run through the rest of your Joe Gibbs break-in oil, and from there on out you can use the Rotella or another similar brand of non- synthetic with the same viscosity.
10-20-2010, 03:36 PM
OK
Cobra Make, Engine: Fords
Originally Posted by blykins
".............Mark, I'd rather you not use synthetic oil at all in this engine. I like the higher viscosity/higher oil pressure................"
I use Mobil 1 15w-50 synthetic oil & couldn't ask for more oil pressure. Ignoring the significant advances in oil technology by advising against synthetic oils borders on willful ignorance.
Here's my oil pressure @ 75- 105 degrees F. air temp. with a 180 degree thermostat
cold engine:
pressure @ idle: 82 psi
hot engine:
idle (800 rpm) ...... 35 psi
1500 rpm ..............70 psi
2000 rpm ..............72 psi
2500 rpm ..............75 psi
3000 rpm ............. 80 psi
3500 rpm ............. 82 psi
4000 rpm ............ 85 psi
5000 rpm ............ 85 psi
6000 rpm ............ 85 psi
6500 rpm ............ 85 psi
Z.
'65 K code Mustang
'66 Galaxie 500
10-20-2010, 05:57 PM
KY
If you noticed his first post, you'll see that he was dealing with 5W and 0W oil...most certainly, he'd have higher oil pressures with a 15W-50 synthetic oil in comparison to those. However, he had a surplus of oil that he was wanting to use.
Regardless, I recommend customers to use the good ole fashioned non-synthetic in my engines.
10-20-2010, 06:20 PM
CA
I'm with you. Unless the manufacturer specifically calls out synthetic (i.e. My wife's MBZ), I'm going to stick with non synthetic for my Roush.
Doug
10-21-2010, 05:40 AM
FL
Cobra Make, Engine: Unique 427 S/C, 427ci
Good opinions by all, and thanks for the feedback.
I will use dino oil for these key reasons: 1. I'll only put 1 or 2k miles per year, 2. I'll change oil annually in the fall, 3. for a few k miles and higher cost of sync oil it just makes NO sense to use sync oil (with very little or no benefit).
The only reason I started this thread was I had sync oil from a previous car.
thanks all again.... Mark
10-21-2010, 11:25 AM
Oye vey. This is why I don't like oil threads. Folks quote studies, with elaborate statistical evidence, but don't know who paid for them or if the people are even qualified to perform a study. Who knows, maybe they're biased, maybe they're not. Maybe they're right, maybe they're not.
Then folks go ahead and call me and others names, like "bordering ignorant", because we prefer dino oil in our engines or even, for heaven's sake, 15W-50 grade dino oil.
The Buddha said (paraphrasing) "Don't believe everything you read."
Reason: added "bordering" to "ignorant"
10-19-2010, 05:47 AM
Me
Most all oil Co say you can mix oils.I for one see no reason to unless have no choice.Why would you feel the need to? Personally have one brand am loyal to Amsoil.Been using all their products for years.
10-19-2010, 06:02 AM
KY
I don't see the need to mix the Redline breakin, with the 10W40, with the Joe Gibbs.
With 15+ pulls on the pump, it's certainly broken in at this point...but I think in his situation, he had about 4 quarts of Joe Gibbs leftover from the dyno and he wanted to just go ahead and use the rest of it. I think it would be perfectly fine to go ahead and run that with the Rotella he has...then just switch to all non-synthetic on the next oil change.
| Thread Tools |
| Display Modes |
Hybrid Mode
