05-16-2011, 07:59 AM
Cobra Make, Engine: 427
2415 pounds, what does yours weigh?
I've been curious on the actual weight of my cobra , so I took it to the recycling center the other day and weighed her in on their digital scale.
2415 pounds with a quarter tank of gas.
Just wondering what others way in at?
05-16-2011, 08:14 AM
SPF642 - with 1/2 tank of gas - Windsor w Aluminum heads and manifold - Tremec 5 speed
2,600
05-16-2011, 08:18 AM
Ga
Cobra Make, Engine: Superformance aluminum427
Weight
Mine weights 2650 Shelby block 427 FE
05-16-2011, 09:16 AM
1.950lbs
In 1993 I built a UK RAM with all aluminium 496cui Chev. I built it it on scales.
Once I was safely under 2.200lbs (1.000kg) I stressed less. The result was 1.950 lbs with some potential for less.
It still had the XJ brake calipers, heavy 6-pin knock-off adapters and heavy diff.
Boot and bonnets were single skin, single seater windscreen, hardly any interior.
IL
2246 lbs for the current build with the T56 Magnum and 2130 lbs with the Jerico and a button clutch. The original build from E-M was 2820 lbs
05-16-2011, 09:21 AM
2.233lbs
And I had a south african built LDS which tipped 2.233lbs at the scales when I raced it.
05-16-2011, 09:55 AM
WA
SPF 1735, 418W iron block, alum. heads and 1/2 tank of gas - 2505 lbs.
05-16-2011, 10:02 AM
3250.....hehehehe......yep, it's a tank
Fred B
05-16-2011, 10:26 AM
ny
Cobra Make, Engine: A&C,351W
Just got my Antiques & Collectables weighed for NYS registration. 2450lbs. with 1/2 tank of gas. 351W and Tremec 5 speed.
Aaron
05-16-2011, 12:40 PM
2580 with 3/4 tank of gas. Iron W418 with aluminum heads, TKO600.
6th generation Texan....
05-16-2011, 03:20 PM
My Lonestar weighs 2400 even. 351w iron heads. Too bad its 2600 with me in it. I weighed the thing on the scales when I worked tech inspection for a SCCA race here in Houston. Next time I go I want the corner weights so I can dial in the QA1s.
05-16-2011, 04:10 PM
Average Guy
IN
2380 without driver; sbf, iron heads, solid rear axle w/9" center section
05-16-2011, 04:32 PM
N.H
Cobra Make, Engine: 08 Mustang GT
2275 E.M. 460 ford crate its a whole lot heavier when my big a-- gets in it
05-16-2011, 06:20 PM
wi
Cobra Make, Engine: ERA #726 427 SOHC
2808 w/half tank- no driver. all iron 427SOHC
05-16-2011, 07:12 PM
Cobra Make, Engine: Unique #9159 428 FE 614HP by FE Specialties
Mine weighs 2682 with me in it and a full tank of gas. It's professionally set up for the track (road course)...LF 625 RF 614 LR 736 RR 707 46.1 % front weight and 53.9% rear. Big block 428 with 614 hp engine set back 2 1/2" handles like a small block in the turns. Best money I ever spent on the suspension set up.
05-16-2011, 08:17 PM
Cobra Make, Engine: #6101 streetbeast Ingelese stack EFI 351w/t-5 9" 4link 3.55
Why do most of these cars weigh so much? My COBRA is not finished yet,but I was hoping to be under 2300.
05-16-2011, 08:41 PM
Unique with stroked 302 (331"), Tremec 5 spd; 2380 lbs., 3/4 full, no fatass driver.
05-16-2011, 08:43 PM
HI
Cobra Make, Engine: Unique 289 FIA, 347 stroker
Unique FIA with stroked 302 (347"), toploader, 2 gallons of gas, 2400# even.
05-16-2011, 09:00 PM
AL
Lone Star with a small block, 8.8, TKO600, no gas - 2315 lbs. with me and a full tank of gas 2609.
Dwight
05-16-2011, 10:24 PM
Quite interesting how the weights differ - drastically! And not only because of the engine.
