Old 07-18-2011, 02:30 PM
Cobra Make, Engine: D&D Cobra,302 stock for now,IRS
Send a message via Yahoo to michel schryer
Default Request about offset bushings and bump steer kit
Hi guys,
I would like to know what's the procedure to install offset bushing and a bump steer kit on a stock manual mustang rack and pinion. What are the best products.
My steering is too shaky on rough surface even after alignment.
I feel the imperfection of the road too much and I would like to improve that so I would like to know if somebody could give me a little course on how to install those two,pictures of the installation would be awesome too since I understand better when I see things. What are the steps in doing so,thanks a lot for your effort,I appreciate any help,cheers !
Michel
Old 07-18-2011, 03:15 PM
A "bump steer kit" must be specific to your kit and suspension setup. They are not interchangeable.
Measure your bump steer first, then figure out how to correct for it.
Hints from Longacre Racing
Old 07-19-2011, 08:32 AM
I know nothing about suspension set up,I thought any kit would do,thanks for that one,cheers !
Michel
Old 07-19-2011, 10:27 AM
PurpleVenom's Avatar
Cobra Make, Engine: FFR MKII - 460 Crate with Cobra Jet heads, 750 Quick Fuel Carb, and Edelbrock Torker II Intake port matched to heads
Go to site, this site: Breeze Automotive Factory Five Racing
If you still have questions talk to Mark there with Breeze. I have these installed on mine and they really helped.
Hth,
Tim
Old 07-19-2011, 02:26 PM
Thanks Tim.
Michel
Hth,
Tim
Old 07-19-2011, 02:44 PM
Look at my first post... Make sure that Mark is aware that you have a D&D, not a FF.
Old 07-20-2011, 08:36 AM
I told him already,by the way,my tire pressure was extremely high,might make a difference,I will lower it where it should be and see,but this is when I get my car back late summer unfortunatly,thanks
Michel
Old 07-21-2011, 06:13 AM
G-Pete's Avatar
Michel, it has nothing to do with your tire pressure.
Here is an article, easy to understand what's going on...
Bumpsteer Explained - Mustang & Fords Magazine
DRB GT40 MK1 red #49- sold
SPF 2063
Old 07-21-2011, 11:26 AM
bobcowan's Avatar
Michel
Predominantly, bump steer kits change the relationship of the steering rack and the tie rod end. For various suspension set ups, moving the tie rod up or down can decrease bump steer.
The first step is to actually measure bump steer. If you're not racing and your bump steer numbers are really low, you won't accomplish anything except make your wallet lighter.
If you have a handeling problem, and your bump numbers are really low, look somewhere else for the answer. Don't guess - know.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 07-22-2011, 05:10 AM
G-Pete's Avatar
...the article includes that too.
SPF 2063
Old 07-22-2011, 01:42 PM
bobcowan's Avatar
Yes, it does. Between that article and the one from Longacre, you should be able to get the job. Both are very good, and very technical. And, you don't need to spend big bux on equipment, either.
.boB "Iron Man"
